Ti is ...much more difficult to work with
From a maker's perspective, however, my choice would depend on the equipment available to me, as I haven't worked with Ti yet. If I had anything short of a CNC mill, I would probably choose steel every time. I believe 6Al4V is something like 45 HRC, which would be a pain to work with hand tools, especially on a thick framelock. Give me annealed steel, if it works like butter I can spend a whole day filing and enjoy it.
I'd have to respectfully disagree with you on galling. Carbidizing only delays its happening. It will wear off, or more accurately, it will get scrapped off after a bit of use. Carbidizing doesn't last forever.
I agree however, that titanium is a great choice for a very high tolerance to corrosion! I remove broken taps by soaking in cedric chloride over night. Doesn't touch it.
I dont' think it's that hard to work with.
I an drill and hacksaw it easily enough.
Tapping is a bit springy different but not impossible.
Especially if you are comparing stainless to Ti
Not that different, give it a try.
I just assumed, based off of the hardness of the material. I wouldn't think that's the sole arbiter of machining properties though, so it very much makes sense to me that this is the case. That just makes me that much more excited to experiment with titanium. I'm just waiting until I have an actual use for it. I still have lots to learn, and very much look forward to it.
I have started paying more attention to folders of late as i may actually have to go over to the dark side and make some at some point. What I have noticed is that a lot of the frame lock knives are iMO, not frame locks but "handle scale locks" in that even in the case of a knife that has a handle scale of a different material on the non-locking side, the lock side is actually a handle scale that is the same thickness as the combination of the thin liner and the scale on the other side. What puzzles me is that on many of these knives, the lock bar portion of the Ti scale has to be seriously milled out up by the base I am guessing in order for it to be 'springy" enough to be useful as a locking mechanism. Aside from perhaps a bigger bearing surface where the bar contacts the blade or maybe it being stiffer in the middle, what is the real advantage of the frame lock setup when done like this other than just looking cool? It doesn't seem like it would be that much stronger than the thinnest point along the lock bar which, to my eye, doesn't really appear to be any thicker than a liner lock bar of the same material. Enquiring minds want to know.![]()
They aren't any stronger, and are actually possibly weaker than a linerlock.I have started paying more attention to folders of late as i may actually have to go over to the dark side and make some at some point. What I have noticed is that a lot of the frame lock knives are iMO, not frame locks but "handle scale locks" in that even in the case of a knife that has a handle scale of a different material on the non-locking side, the lock side is actually a handle scale that is the same thickness as the combination of the thin liner and the scale on the other side. What puzzles me is that on many of these knives, the lock bar portion of the Ti scale has to be seriously milled out up by the base I am guessing in order for it to be 'springy" enough to be useful as a locking mechanism. Aside from perhaps a bigger bearing surface where the bar contacts the blade or maybe it being stiffer in the middle, what is the real advantage of the frame lock setup when done like this other than just looking cool? It doesn't seem like it would be that much stronger than the thinnest point along the lock bar which, to my eye, doesn't really appear to be any thicker than a liner lock bar of the same material. Enquiring minds want to know.![]()
