Key wording is "in comparison" to the tnt, the regulator Is softer.The tnt guard is much harder, doesn't budge at all. My parkerized regulator like the one posted above is spongy in comparison and has some give.
The TNT-15 handle is Resiprene-C.
The only difference is the hardness. The TNT-15 handle is identical in hardness to our only other textured handle: the "Mudder Handle".
Both of our textured handles are made with a higher hardness than our smooth handles for durability and extreme use.
The TNT-15 handle was designed for heavy use but can still be bent in half without tearing or suffering any damage whatsoever.
The TNT-15 exhibits Excellent shock absorption.
Dumpster Dan
Yup he said that......Here's what Dan had to say
.....but it's Not spongy!!! It's grippy, with just a tiny hint of movement.
Which could be thought of as absorbing impact
It's probably the perfect chopper handle material.
I'd take the "softer" version Any day.![]()
I'll let you know.....I would be all over the DT12 if it had a Regulator handle, but with a straight handle made from harder rubber, I'm not sure it would be easy to hang onto a blade with that much weight.
