That's not how it works.You are not deforming or bending any part of the edge with a strop. Burrs happen as a result of abrasive contact and amount of pressure exerted on the bevel. A abrasive choice of coarse or fine does not change toughness, wear resistance, or edge stability. It's also up to the user to use proper cutting technique with each edge type, if not you may think that edge type is inferior.A high polish could also theoretically lead to an edge that dies quickly. The more you strop and edge, the more you're deforming the very edge of the steel, back and forth on each strop stroke. This is at a very tiny level, but it's there. If the edge is extremely thin, the amount of effected steel could be great enough to create a wire edge
