Ok , i just put one of my deer antlers on and it was short of reaching the guard.
what do you guys use for a fancy filler?
second, where do u buy this
thanks vern
If it is a narrow gap you might try this. Mix up some epoxy and color to suit. then fill and sand smooth. I have used JB Weld and mixed in sifted brass chips from my mill and then sanded and polished. leaves little brass spots and etc on the surface.
the hidden tang , is about 1/2 " from touching and at the angle i drilled it if i try to drill any more , it will come out the side or the antler .
vern
Why Dont You File Out A Fitting To Go Between The Gaurd & Antler?
Maybe Some 416ss Or Ns. Or You Could Use Some Maroon Micarta With Some Sheet Ns Or Brass Spacers.....etc
