- Mar 8, 2008
Once again some great discussion however if you think about the bottom of a kerf, the wedge should not be able to be driven that far, it should do its job before that point and never quite reach it. In my experience, if it does, then the wedge should be thicker because either the wedge or the sides of the kerf are compressing enough to allow the wedge to bottom out. That should not be allowed to happen and there is no real advantage in having it bottom out. Sure there is the argument that filling that little void is the ultimate but for the percentage difference it makes to the overall effectiveness or resilience of the axe, it is negligible.
And if you took a wedge that was able to bottom out in the kerf at full appropriate depth and drove it into a split you'd end up driving it too deep and probably crack the haft.
At any rate, the method doesn't matter so much, ultimately, as the end result. If you can haft an axe securely with either method without resulting issues then who cares which method you used?
