As someone who bought an Edge Pro, was disappointed, and then sold it and bought a Wicked Edge, I have to endorse the latter. They both can yield the same results, but the process by which you receive them is vastly superior on the Wicked Edge IMO. There is way less human error involved, which is a huge part of the Edge Pro. There's far more variables on the EP that are difficult to control in comparison to the WE, especially stone thickness. It's a little absurd that the EP doesn't come with the drill collar stop when it's almost entirely necessary in order to ensure consistent angles. Not to mention the setup time and the mess that comes with the EP is frustrating.
I bought a Wicked Edge because I wanted consistency, and that's what I got. Very much worth the cost of entry. I was happy with the edges I was getting starting with my second knife.
Unless the stones are of distinctly varying thickness, the initial angle setting should be good.On the WEPs dont you have to use the angle cube every time you change stones though? At least if your using any waterstones (thickness on the diamonds should be pretty close accross the board). But a set like the shaptons would require checking the angle cube on each arm every stone change wouldnt it?
Some people (such as yourself) prefer a fixed jig for the reasons you mentioned. But some people want to transition to freehand later on and I believe that the EP is better suited to those people. It teaches muscle memory and forces you to use your off hand. This presents a learning curve that is not really a factor in something like the WEPs. This is something I like about the edge pro , and others dislike it.
The drill stop collar should come with every model of the edge pro i agree. On the WEPs dont you have to use the angle cube every time you change stones though? At least if your using any waterstones (thickness on the diamonds should be pretty close accross the board). But a set like the shaptons would require checking the angle cube on each arm every stone change wouldnt it?
If you are using waterstones, than yes you would have to do the same procedure with the WE as well. They did recently come out with an adapter for the WE that works the same way as the drill collar stop, but in traditional WE fashion it's very expensive.
The funny thing is that I learned how to freehand sharpen first, before I bought any of the jig systems. But seeing as how 90% of production knives need to be reprofiled out of the box to reach high levels of sharpness or cutting performance, I wanted something that could very precisely reprofile. I still touch my knives up freehand, which I think is the quickest and easy way to do it. I would love to get some nice, high grit waterstones to touch my edges up after I've put an even bevel on them.
- Really? Considering the cost of the knives that members of this forum own, sharpening their knives should be very high on the list of importance.I think there is a limit to how much we should be expected to pay to sharpen our knives. Wicked Edge pushes that limit.
Sorry, I didn't mean to come off harsh. My point was that if I'm going to sharpen a several hundred dollar knife with my limited sharpening skills, I want the most idiot proof system out there.I never said sharpening knives wasn't important. This board is big enough to share different opinions and exchange ideas in a constructive way.
What makes them gimmicky? Interested because might buy said system in near future.The edge pro is an excellent system.
However the polishing tapes are gimmicky and are cost ineffecient long term.
Buy a base model EPA or EPP and add a handfull of aftermarket stones and strops. It helps build some muscle memory , teaches you the basics and makes for an easier transition to freehand later on if you so choose. Buy the right set of aftermarket stones and if you decide to stick with the EP then you can easily build on that set.
So a base model EPA would pair well with a set like this
140 Atoma , Nubatama 150 , 1k , 4k and 8k.
140 Atoma Shapton (Pro) 220 , 1500 , 5k and 8k.
You could add a nanocloth or kangaroo strop with some 0.75u CBN to push things a little further if you felt so inclined.
You are in the hobby for the knives, not to be super proficient at sharpening.
