If you have ever wanted a true masterpiece in the form of a knife, this is it, Todd Begg's "Beggatti" a larger version of his "Bodega". The knife exudes quality, imagination and craftsmanship unlike any other and is another great example of his work. Im the second owner of this knife, which appears to have spent 99% of its time in a padded case and only occasionally carried. The detent is on the strong side and the blade flies open and falls shut smoothly under its own weight. Blade is centered perfectly and lockup is early and solid. Slight occasional lock stick and zero blade play. The blade shows zero wear, but it has been re-sharpened. Razor sharp for such a thick blade and definitely sharper than other original Beggatti edges Ive experienced. Also, one very light scuff/scratch near the tip of the blade on presentation side; only noticeable from certain angles.
NOTE: Although listed as Blue Anodized, the scales are definitely NOT bright blue as pictured in Stock photos. I would describe it as a subdued grayish blue or a bluish gray depending upon the light. Also the gold scallops are a lighter gold color as well. Personally, I like actual colors better because they are not as flashy as the bright blue and gold. Photos are of actual knife taken at different times; more available upon request,
Details per Todd Begg Design:
This frame lock flipper features a .250 inch thick Carpenter XHP Compound hand ground blade and 6AL4V Titanium scales that have been tumbled and given a scallop pattern. This one has a two-tone gold scallop texture and blue anodized handle, with gold anodized accents. The Beggatti is equipped with IKBS ball bearing system and also features the Begg designed replaceable titanium lock bar with built in over bend and ceramic detent compression protection as well as a tumbled titanium checkered back spacer and pocket clip.
Features:
Tumbled Carpenter XHP Stainless Steel double tempered Compound hand ground blade.
Patent pending removable 6AL4V titanium bolt on lock
IKBS (upgradeable to ceramic)
Ceramic detent
6AL4V Titanium diamond checkered back spacer features a partially raised section of jimping for reverse grip control
Blade length: 3.875
Overall length: 8.875″
Weight: 9.7 oz.
Blade thickness: .250
Right hand tip up carry
~~~PRICED TO SELL~~~POUCH & COA~~~AS IS~~~NO TRADES~~~NO RETURNS~~~
Asking: $1630.00 TYD, or OBO. Terms: Payment via PayPal only, includes PP fees and 2nd day priority USPS shipping. Seller only ships to the lower 48/CONUS and reserves the right to sell to whoever he chooses. First "I'll Take It" followed by immediate email to: badasur@hotmail.com - becomes the new owner upon receipt of funding, which must occur within 2 hours of being told "It's Yours".
THANKS FOR LOOKING !!!
Features:
Ceramic detent
Blade length: 3.875
Weight: 9.7 oz.
