Todd Rexford , Helmut Pirklbauer, Wantanabe, Seibert, Warren Thomas, Extrema Ratio
Liu Kang
BANNED
Feedback: +813 / =1 / -4
Thread has been moved to:
http://www.bladeforums.com/forums/showthread.php/864021
Todd Rexford Fallout
.1875" Thick CPM154 Steel
8.5" Acid etched blade. 14" OVL
Carbon Fiber Handle
Helmut Pirklbauer 2-Way
Function:
If you press the button, the blade is unlocked.
Locking at 90 degrees, you can use it as a push knife.
Locking at 180 degrees, you can use it as a typical folding knife.
Specs:
Blade steel: N690Co
(plain, spear point with top swedge, a kind of two tone finish – bead blast and polished triangle patterns)
Liners and Clip: Titanium
Handle: Carbon Fiber
Length closed: 5.315”
Blade length (using as a push knife): 3.228”
Blade length (using as a folder): 2.441”
Usable cutting length: 2.362”
Blade thickness (at the ricasso): 0.157”
Weight: 0.384 pounds (6.14 ounces)
This was bought this knife on Aug-3-2010 from an Austrian knife dealer with a listed price of $1280.00. Excellent condition with no blade play. The blade is centered between two thick Ti liners.
Wayne Wantanabe Medium, 4.5-3/8" D2 Blade 9" Overall, Menuki with rayskin .16" Thick Chisel Ground.
Wayne Wantanabe Small, 4.5" A2 Tanto Blade 9" Overall .125" Thick Chisel Ground
Warren Thomas Fred Perrrin LaGriffe - Titanium – Bowie
SPECIFICATION
Warren Thomas - Perrin LaGriffe - Titanium – Bowie
Solid .214" 6al4v Titanium
Satin Finished body with WT's signature Fingerprint Anodizing.
5-1/4" OAL
2" Blade, Chisel Ground and Carbodized.
1.4 oz.
Kydex included.
This batch are Right Hand Ground.
Extrema Ratio RAO
NEW IN BOX
5 5/8" closed. N690 stainless blade with Testudo finish. Extra safe locking device is a steel pin that is hand screwed into place, locking blade open or closed. Black anodized anticorodal aluminum alloy handles. Lanyard. OD green nylon sheath is MOLLE compatible and holds diamond sharpener. Sheath can accommodate knife in open or closed position. Made in Italy.
Shane Seibert ALPINE EXPLORER!
Specs:
5” blade, 3/16” thick S30V
416 S.S guard
Canvas Micarta handle
Flared Titanium tubing
Rounded spine
6.5oz
This knife is NEW with a Black Leather Custom Lifters Sheath.
