Tom Mayo Titanium Frame Lock Folder with Talonite® Blade (large with pictures)
stjames
Sebenzanista
Also known as a TNT, just in case this is your first day on the Forum ;)
I have been interested in getting one of Tom’s Talonite® frame locks since before he started making them, a Cop named Fish was bragging well before he had the first knife in hand. It took a while for me to decide just what I wanted in this knife, and here are the results:
2-3/4” blade and 6-1/2” overall, it differs from most of the TNT’s you might have seen in that it has no holes in the handle besides the one for the lanyard and no clip has been attached. I also opted for an ambidextrous thumb stud as opposed to an opening hole in the blade. I am very happy with the combination of features; it is a useful, friendly size with a clean, classy look.
The smooth contours fit well in the pocket and the hand, the small “bumps” on the pivot end of the handle serving as a slight thumb rest and guard to give it a solid three-finger grip. All tolerances on the knife are very tight, the opening action is smooth and easy, and the lock bar engages slightly but firmly. I am especially happy with the tension of the lock bar, many frame locks are either too tight to disengage easily or, more commonly, too loose and able to be flexed past “true” and be prone to wobbling. Not only is the lock on mine “just right”, but all the knives that Tom displayed at a recent show had similarly fine action and lock-up. That kind of consistency is one of the things I look for in a knife maker, and it assures that more of my hard-earned cash will be making it’s way to the 50th state in the future.
The handle is smooth and very comfortable; no strait lines or sharp edges (except the one we want on the blade). Note that the cutout on the lock bar that allows it to flex is on the outside of the titanium slab and how you can clearly see that the handle thins out nicely towards the edge. The thumbstuds are somewhat smooth and might not be the best choice if you are looking for a rapid-deployment fighting folder, but on a small, gentlemanly pocket knife they work well, not snagging on threads or material when loose in pocket or being removed.
The Talonite® blade takes a nice satin finish, attractive but it shouldn’t be too tough to maintain. The surface of the handle is especially nice, it might look like your regular plain gray titanium but it seems to have a “hard” finish that resists scratching better than the polished and blasted finishes I’ve come across in the past. Scratches on plain titanium are inevitable, but they don’t seem to be coming fast and furious on this knife they way they will on others I am used to.
Talonite’s® main advantage is that it is corrosion proof, of course, and the hard facing materiel holds a good edge for a surprisingly long time. It does not have the overall strength of an iron based steel, however, so like most things in life there are compromises involved when deciding to use it as a blade steel. Tom’s solution seems to be a flat grind combined with a wide convex edge bevel to ease the blade into the materiel being cut. It works very well on a knife of this size, were levering and torqueing are minimized and pure cutting ability is what you are looking for. This little knife is a real slicer, not aggressive but extremely smooth. It loves meat and other food products, and the lack of worry over rust makes it an “apple and sandwich knife” supreme. I’ve also used it on just about everything else I have to cut in a day, all kinds of tape, plastic, rope, string and cardboard and the edge is holding up well without dulling, rolling or chipping.
I really couldn’t be much happier with the knife; the great advantage of working with a custom knife maker is that you can get exactly what you want. Make no mistake; the design is all Tom’s, I just kept looking at his work and checking into the options until I knew what I wanted him to make from his repertory and the options I preferred. It took a while, but when I finally made up my mind Tom was able to put it together in time to bring it to me personally when he visited the Bay Area, so I had the additional bonus of getting to meet him and his lovely wife. I wish I had gotten to spend some more time with him, but it was a busy day for us both, and so little time, so much to know! I do look forward to getting to know him better over the years as the fun and the knives keep rolling in, and would recommend his work wholeheartedly to any interested parties. Thanks again for the great knife, Tom, and for being such a joy to work with.
WOW!~~~~!
how much do I owe you for that!! :)
Thanks James.....it was a PLEASURE making you that knife...
hoping that it would come out as good as you expected!!! :p
Told ya! :) Hey all you forumites, Tom Mayo does great work and he is a great guy to boot! If you want to jump on the custom knife bandwagon, you can't go wrong with a TNT! Just for those that are wondering, no, I don't get a commission! Do I. Tom?
Great looking knife and perfect size too. I love the Mayo's with no holes and that is only the second one I have seen. That size is great for pocket carry but still big enough for most jobs.
stjames -- looks like you told him you wanted his version of a Sebenza. In between the Umfaan and a small Sebe. So... how does it compare to all those Sebenzas you have. Probably not a fair comparison. I am sure that little gem is worth every penny -- very nice.
JT
another "card carrying" TNT member joins the club:)
Nice review James and great little knife you got there.... I missed seeing your knife in person at BAKCA, but those are some nice pics to show it off.....
for an "ol" surf bum;) :p ......he does a FINE job.....
doesn't do to bad in the fixed blade dept. either...
....I picked up this bowie from him at the BAKCA show...its the large one on top in this pic.....double edged and the sharpest blade I own right now, both edges.....beautifully executed double hollow grind...
.....he calls it a Combat Bowie....with a 7" blade and about 12 1/2" OAL.......
......5/16" stock of 154CM....... blasted black linen micarta, blasted nickel silver guard, and a grip that fits the hand with perfection no matter what size your hand is..( I saw several guys try it on for size)
the TNT in the pic is about the size of your blade I think......
Tom, thank you once again, the knife is a pleasure to use and turned out just as I'd hoped.
I did ask Tom not to use two of the signature features of the TNT line on this knife, no holes in handle or blade. Personal tastes and preferences really, but I admit to having the bad habit of finding something I like and sticking with it. My wife sometimes finds this boring, but I like to point out that it works to her advantage in that I don’t let my eye wander much. Much ;)
Having seen this one in person, I think it's still very much a TNT, and would never be mistaken for a Sebenza. The lack of holes make it look a bit dressier, something that may not be obvious from the pictures. I really like this size, as you can't haul a huge tactical knife around everywhere, especially these days. Right now, I'm carrying either an Umfaan, Mnandi, or Chive--but I am looking forward to getting a TNT or two, maybe something a little fancy. Tom keeps teasing me about stainless damascus...
stjames,
Really nice piece!
I was lucky enough to see that one before Tom left.
Knowing your fondness for the Sebenza, and your discriminating eye, I'm glad to hear that you like Tom's work.
Aloha
Thanks everybody, I am a proud owner (as sas and anybody else at the BAKCA Show a few weeks back can attest ;) ).
The pictures don't do it justice at all, I had the chance to grab a digital camera so just tossed it on my workbench and clicked away for a minute. The shot with a quarter was a last second one, I keep forgetting how important it is to have something for scale. Like I said, a classy little folder, and it definitely shows Tom's style. Definitely worth every cent, as fine a folder as I own.
Very nice knife. I too prefer the TNT's without the holes in the handle or blade. I really like the blade profile as well. I had pretty much been bypassing the TNT's, maybe it's time to take another look. Enjoy!
Oh Lord!!!!! I got to get me a Tom Mayo any knife!!!!! Copfish, what do ya want??? machine guns, rockets, cluster bombs, scopes, sniper rifles, M-4's AR's, My First born????hell I will also throw in my wife!!!!! ( yeah, just wait until I figure how to put her picture here, Penthouse lady!!!!) Oh, please tom, throw a knife towards New England!!!!!!
wolf on my knees (Here is your lunch!!!!) LOL;)
James-
Very well written review with great pictures! Welcome to the TNT club. I got to meet you very briefly at BAKCA but I didn't get to see this knife. Glad that I got to see it here.
-Steven
I bought a Tom Mayo folder a year ago. It was so pretty that for about six months all I did was look at it and show it to people. I went to the Eugene show with the knife in the original wrapping. Will Fennell of Camillus told me that I should use it. His point was that there was nothing I could do to it that Tom couldn't polish out in a few minutes. The first time I used it was to cut steak at the Talonite dinner. Six months later I was working in shipping and cutting boxes and everything else. I still cringe when I hit a hidden staple but the knife holds up.
It is a very beautiful knife but it is an even better tool. I hope you enjoy yours as much as I enjoy mine.
Tom
Great post James!
That TNT you received from Tom at BAKCA is definitely a looker! Glad to see it has made it into your collection and that you're pleased with it.
Now all you need are one of Tom's talonite neck knives and Combat Bowies and you are set for the Opera House! ;)
It was good to see you again at the show. Hope you're well.
-Jerome
Oh man.......that's SWEET!!!
Does it feel as good as it looks?
Tom, very nice work....very nice indeed.
Paul
I agree that Tom makes a fine folder, this one is a great high performance pocket knife!
Jerome, the neck knife you picked up was very nice as well, and I guess the Bowie would work as well backstage as anywhere. ;)
I swiped a picture from BladeArt of a model much like mine, but with blade hole and patterened handle:
And here is the lockbar side, including one of those clip do-dads:
It don't mean a thing, if it aint got those holes... :D
Very nice indeed! You mentioned that the cutout of the locking bar is on the outside. Why is this so? Would look nicer if it was hidden...
Hugo.
