So your saying it's to tough?
No, "I think" in general folks misuse/misunderstand the term "tough" as it relates to things. In this case focus will be on tough as it relates to bladed tools (from my perspective).
In this case let's consider what we want tough to mean as it relates to improved performance over the lifecycle.
A positive performance characteristic of CPM3V is that the edge can be ground thinner while still retaining equal of even possibly superior toughness to other steels, say for example 1095. CPM3V can be heat treated to higher optimal RC of say 60rc vs 56rc for 1095 (optimal being related to the specifics of the individual steel, each steel having an optimal range of RC). The net result is a thinner (slicer) blade of equal or higher hardness.
To summarize: the positive performance characteristic of 3V over say 1095 is that it has greater toughness at higher hardness across thinner sections. Is our goal in designing a tomahawk to make a thinner blade, and or one with fine grained micro-structure (characteristic related to CPM technology more specifically PM technology if you remove the Crucible proprietary name from the actual manufacturing designation). I personally think not. Example: I want a tomahawk to be a good wood-splitter, to do this it needs to have wedging characteristic performance (described it greater detail below). Now maybe if someone says they want a tomahawk to be a good slicer (say maybe a can-opener like for breaching thin sheet metal then perhaps there may be positive characteristics worth exploring here and we move on to other "design parameters" in discussion of optimal steel selection for specific design purpose of the tool in question).
Now let's consider "toughness" as it relates to "strength" (specifically with consideration for strength against lateral stress or in this example bending). The most value (increase in strength) comes from increase in thickness (resistance to bending is cubically proportional to thickness). As example: a 2x increase in thickness from 1/8" to 1/4" yields an increase in stiffness of 8x (8-times the force is required to yield an equal amount of lateral (sideways) amount of flex. Reducing thickness unfortunately has less proportional overall benefit (I forget the factor, other than to say it's significantly less that a cubic ratio. So does our design goal include wanting a thinner tool with equal to greater strength? I think we already said no (exception may be as referenced above that perhaps we want slicer performance enhancement and are willing to accept decreases in performance on other areas to achieve this goal). Again, not a worthwhile sacrifice in my mind for a tomahawk (for my use perspectives and design goals).
With regard to "design" based on performance use:
I believe first you must consider geometry. How does the geometry of the blade work towards the purpose. If you want slicey, thin is in (you want thin geometry). Thin however, does not split very well. If you want to be able to split or wedge you want additional thickness. Consider when chopping, the first cut penetration is good. the second cut (opposite side of the V) you want to have penetration and wedging effect to push the wood/media sideways slightly as a self removal effect created by the downward force of the cut. Wedging comes from the thickness geometry. A thin blade geometry will penetrate ok (so long as it can resist deformation to the edge) but will get stuck in wood because of surface contact on the sides of the blade from poor wedging effect).
In general, as thickness increases I would say the positive characteristics of CPM3V diminish (remember that cubic 8x relationship that adding material thickness achieves).
I have two knives, both in CPM3V, that are both great examples of being overly thick to really see a significant performance increase. I bought these with assumption "3V is tough" therefore better. At some point it is my plan to significantly reduce the thickness on both in attempt to net a true performance cutting value. At this point after many comparision sessions with numerous other knife steels and geometries those knives don't see much light of day. When they do, like a couple days ago I brought them both out to retest against a number of other knives (wife gave me permission to harvest some of our standing lilac hardwood a few months back and I saved sections for knife testing purposes) it only took a minute or so with each to get that same sinking feeling "yes, I still need to get these two on the grinder and thin them out ..." to see to potential performance value of CPM3V.
Where "I think" CPM3V may have a future in tomahawks relates to sheet-stock-removal construction, and hawks designed as breaching type tools where slicing and penetration are the primary design goals. AND, were a user is ok with spending a lot of cash versus having mentalitiy that a breaching tools life cycle cost means that replacing a tool after a few uses becomes more cost effective than spending a lot up front. So, like the hawks I previously mentioned like that Dan Keffler similar to what most I think would reconginse today as a Winkler (No disrespect meant twoards either, but a small market share and very expensive value). At least this is my opinion as of today based on my experiences.
So in close, I will say geometry is so much more important than the selection of the steel. Understanding how and what various terms like "toughness" (charaterisitcs of performance goals) mean to the performance and how that relates to the geometry should be considered before just discussiong something like toughness. This approach should be followed all the way through to the heat treating and tempering process (because both these processes SIGNIFICANTLY affect the overall performance of the steel with regard to being able to support the design geometry).
Hope some of this makes sence, sorry for the length. Rehashing things in my mind helps to reinforce what I "think" I have learned and as always it seems
"the more I learn, the less I know" (but, the overall understanding continually increases ;-)
Regards,
Christopher
