- Aug 6, 2007
At the risk of putting myself out of some business, here is a demo on how I make tongs,I get better with every pair too. I try and try everytime to make tongs as good as Grant made, he really set the bar high. Tongs should be light yet tough springy yet strong gripping. I make them from mild steel, I start with 1" wide by 3/8" thick by 8" long, this gives me enough for a good bolt tong with about 16" reigns, for pickup or pincer tongs I start with a 7" piece cause you don't need so much for the jaws.
Starting stock:
Here is an illustration of the shouldering I will do, I layout measurements, 1" square area for the actually part that grips the metal, then 1 1/2" for forging into the jaw neck, then another 1" square area for the rivet area then shoulder off and draw the reigns.
I dimple the steel in the locations I need, I can see this dimple while the steel is hot but it does not effect the finished forging, like a hot cut mark or a center punch mark would.
Starting stock:
