likem said:
TOO MANY SHARPENERS and opinions ---- I have a birthday comming up and need a sherpener for a wide veriety of knives. The forums I know will say the Sharpmaker-But there is always a post following that it will not do it all. I am a poor sharpener and worked on my SAK last night and used first a rough silicone carbige then a smooth bench stones. Did not like the results at all.
Took a tool that has a blade clamp and three slots. The hone has one shaft and four stones mounted on it and you rotate as needed. I do not know the maker but had it in storage for about 8 years. It has Heavy, medium, Fine grit and one grooved for seratted. I went through all three stones at the lowest angle and then went to a higher angle. Now my SAK has a straight edge instead of the shaped rounded form blade shape. I think I lost about 15% of the steel.
It is now sharp but will not pop a hair as some of the posters claim. What will do a good job on a knife without killing the profile of the blade shape and giving a razor edge? Here is a link to the blade photo.
http://members.sparedollar.com/knife2b/sak.JPG Take a look at this. And tell me is this what I am after and if so I think if I did this 6 more times would there be any blade left to use. ------ Thanks likem
Do not be sad...You just accidentally created a Wharncliffe bladed Swiss Army Knife!
I second the suggestion of an EdgePro. You can see your reflection in the edge if you finish on the polishing tapes.
Though for THAT knife, I would go the mousepad with sandpaper route...The way you multi-beveled that edge, you are well on the way to a convex edge anyway! That will actually make converting it to a nice convex a lot easier. Take one of the course stones and use it freehand to round off the transition points between bevels...Consentrate on the main one between the BACK of the blade and the first bevel.
Then get out the mouse pad and some 150 to 200 grit sandpaper and put it on the mouse pad and lay the blade flat on the paper and then raise the back just a LITTLE, and PULL the blade, edge TRAILING over the paper...
Count the passes you have to make to raise a burr along the top of the blade, then turn the blade over and do the same number on the other side...That SHOULD raise a burr on the side you did first. If not, then start counting again, and continue until you do raise a burr, then do the other side again for the same number of passes and check for a burr.
Make sure the burr is along the entire edge and that you have produced one on each side(not at the same time of course before going to a finer grit of sandpaper... I use something like 80,100,150,200,350,400,600,800,1000,1200,2000,2500,and then the 6000 and 12000 polishing papers. You do not have to use nearly as many grades as I do, but the more you do, the less passes you have to make with each grade before you go to the next grade, and also, I am trying to produce a mirror finish(they just look SO nice).
I find the sharpmaker requires MUCH more skill than either the EdgePro or the mousepad/sandpaper method, and has never given me as good of an edge.
