is linseed oil okay for leather? I had thought about it when all this started..I feel committed with the neatsfoot, I am on a budget so I only buy what I need. I WILL be applying pure beeswax to my wood handles for water proofing, not sure if it needs oil in there or not, from what I have read pure beeswax absorbed into wood is more than adequate to protect it from the elements, am I wrong in this thinking?
On another note, I have thought about how I am going to proceed with this current mix I made. I think i'll stick with the 1:1 and only apply 1 coat for an initial absorbtion. And it will be a thinner coat, not a liberal coat. Then after that I'll do pure beeswax into the leather for another 2 coats. I am hoping that the neatsfoot will be enough to keep the leather from being rock hard.
I might test this on a small piece first. Thanks again for all the help guys, I'll be posting pics soon of my first sheath.
Linseed oil is primarily used on wood as a preservative. I would not think it necessarily a good idea to use on leather on its own....except as perhaps an "initial" oiling of that leather if it were too dry to begin with. In honesty, there are more appropriate dressings for leather.
Neatsfoot oil is one of those "more appropriate" products for leather.
Beeswax is also appropriate for both wood and leather...as a lubricant and waterproof agent. Using heat to gain absorption is the best method I have found.
Take a beeswax candle and rub it onto a scrap of leather and a scrap of wood. Make sure the test piece is completely covered.
Use either a heat gun on LOW or a hair dryer on HIGH [with heat] and make passes over the items to see how it gets "sucked in." Feel the items after it cools.......no residue and no 'tacky' feeling. Now sprinkle water on them to see the repellent nature it shows.
EDIT: If you look at my waterproofing compound posted above, it does contain a small amount of linseed oil........but it's not the "primary" ingredient....that is actually the beeswax. in this 'concoction' it's awesome on leather.....but again, it's part of a mixture and diluted by the other compounds.
