If heat treating is what makes a chunk of steel a knife, I think putting the right edge on it is what makes a knife a useful tool. In the last couple years of not making knives, I've given these two things a great deal of thought.
jerkit
What psyches me about this post is that alternative I'd never really considered - stroping the wire off. Hm.
I've always just buffed the wire edge off on pink or white compound, at a moderately steeper angle than the edge. The relative "toothiness" of the edge grind isn't effected if I do this right and I (hopefully) end up with a shaving edge that will do its assigned work.
Stroping though - that seems like an even better way to retain the "tooth." Guess I'm going to have to give this a try. That being said, what's a good material to use? Will veg tanned leather work? Or do I need to find an actual strop? What if anything, do you use on it? Using an old grinding belt might be okay too if I could keep from screwing up my finish...
(Fred, I'm going to have to stay away from stones - I am absolutely the
worst honing person you will ever know...)
