What kind of compound do you guys think would be best coming off a 1000 stone? I still don't really want to pay the price for a good finishing stone and the MDF with CrO was just a cheap strop solution that I figured would work better than plain leather.
I figure that coming off a 1000 grit stone using something like 9 or 3 micron compound would probably be really fine and work better for taking the burr off... The CrO seems to work for the stubborn wire-edges that stick on, but not without a lot of strokes, and it won't really touch the big burrs. So it would be nice to find something a little coarser to strop the burr off with.
Also, the edge seems to be pretty nice now. Had to cut up some dusty cardboard... Not a huge task amount but enough where I'd expect to see more change on the edge if there was a wire left. Definitely like the 30* inclusive geometry more, went through the cardboard like butter.
. ANother option is to just work up a slurry on your 1000 grit side with a bit of water and rub that across some scrap leather - it should work great. BTW those Norton waterstones wear fast, are you keeping it lapped flat?
ok so i assume you never flatten it ?
i'm sorry buddy but from my experience (10 years+ using waterstones daily to maintan my work knives, worn several stones ....) just after the sharpening you've done on this izula, your stone needs flattening BAD ... the 220 even worst.
a 1K stone shouldn't do more than 2 serious sharpening without lapping, a 220 i usually flatten after every sharpening and i even have to during a session sometimes, especially when working on smaller blades where the flat is less than the width of the stone. you can try to limit this by turning the stone 180° from time to time and focusing on using all the surface. but this is something i'd rather eliminate until you're fairly good at everything else.
I have to ask, are you giving that stone a good soak and adding a bit of water to it as you go? I like the waterstones - they're not my favorite, but they work well and one of the best features is the amount of feedback. I find its almost impossible for me to miss a bevel and can feel and hit the apex dead-on, even on a convex edge, very easily - as long as the stone doesn't dry out. Use that Sharpie and you're sure to improve how well you hit the bevel.
as you found out, you can't use the marker trick on waterstones like on diamond stones due to the slurry. you can't paint your bevel and go to work checking from time to time where your are. the idea here is to work your bevel, check by painting it, wiping the stone and making a couple strokes. then adjust accordingly.
in fact even with diamond stone you have to repaint the bevel from time to time because one stroke too obtuse can wipe all the marker even if the actual bevel you're working on isn't going all the way to the edge.
