I took apart my Military to clean since it was feeling a little gritty. I had done the pivot screw and was working on the screws for the stop bar when one of them stripped to the point where I can't adjust it. I decided just to blow out what I could around the pivot area and put it back together. Once re-adjusted to eliminate play and the screws were set, I noticed the lock was not engaging nearly as much as it was, barely getting half the width of the lock bar under the blade tang. It appears to be locking up securely, but it kind of makes me hesitent to use the knife for the time being. I tried a few hard flicks to see if that would set the liner back to where it was and now it's just fully engaging, but still slightly more to the left than before.
Do you think the knife is good to use as is, or should I try taking the pivot screw apart and redoing that? What about sending it to Golden for adjustment? Would it be possible to get the smaller stop pin screw through the mail?
Thanks in advanced.
Thanks in advanced.
