RokJok
- Oct 6, 2000
I recently got one of these Gerber Brush Thinners (billhook) from Sportsman's Warehouse. Its relatively easy handling length/weight/balance let it work surprisingly well chopping up some alder and applewood branches. It did a good job on the supple tips that would approximate a "flexible but tough" blackberry stalk.
I recall someone posting that this unit was the chopper most borrowed from them by local indigenous people (Costa Rica IIRC). Given its performance, I'm sort of surprised by the billhook's lack of attention from the knife knuts here on the forums. Guess the folks who like curves are too busy over in the Khukri section.
The Gerber came with a funky plastic carry sheath/case that was too big to wear on your belt and had no provision for transport other than a hand-carry handle on top. The modifications I see for this lightweight chopper are some kind of workable sheath for belt carry and maybe some grip tape.
Overall Length: 19.75''
Length of Blade: 8.75''
Blade thickness at spine: 0.11" (just under 1/8")
Blade width - spine to edge at ricasso: 2.2"
Blade width - spine to tip of hook: about 4.5"
Height of grind: 0.28" (about 5/32")
Weight: 15.1 oz.
(edit to add) BTW, the handle is hollow, so if you don't mind messing with the balance of the knife, you could stash some emergency goodies in there. The hollow space inside the handle is approximately 1" high, 3/4" wide, and 8" long. The lanyard hole is just over 5/16" wide and the hole in the blade for hanging is 0.4" across.
Weight: 15.1 oz.
