Looked into them a bit. Not sure if I understand it right. It's measuring the force to push cut through a small aluminum wire more or less.
These discussions always seem to devolve into semantic debates. The BESS result is just a proxy for the width of the edge apex. The smaller the apex, the lower the score will be. A BESS score of around 300 signifies an apex width of around 0.6 microns. A BESS score of around 50 equates to an apex width of about 0.1 microns. That's true of a polished edge which will excel at push cuts as well as a toothy edge that will excel at slice cuts. In either case, the edge with the narrower apex will cut better than the edge with a wider apex, so the BESS score is relevant no matter what kind of edge you prefer.Looked into them a bit. Not sure if I understand it right. It's measuring the force to push cut through a small aluminum wire more or less. Seems like if you want to quantify sharpness it'd take into account both push and slice cutting.
It's good simple fun to take a mirror polished edge to a nylon strap with tons of tension too. You barely make contact across the web and it pops n goes flying.
Tension matters to a degree, but in my experience the biggest variable by far is speed. I can easily get <30 BESS scores if I pull the string tight and then bring the blade down fast, like a guillotine. OTOH, I can get *very* consistent results if I pull the string just tight enough to remove any slack and then take 3-4 seconds from the time weight begins to register until it breaks.It's interesting you mention the tensioning, because this is the exact reason how some guys make videos with insanely low BESS numbers (less than 5 in some cases) with their Edge-on-up testers. The test can be very flawed.
There really is no real proper standard and numbers can be wildly different depending on how the line is tensioned.
I haven't tried cheating the tester, always going very slow, but am aware of the methods people use.Tension matters to a degree, but in my experience the biggest variable by far is speed. I can easily get <30 BESS scores if I pull the string tight and then bring the blade down fast, like a guillotine. OTOH, I can get *very* consistent results if I pull the string just tight enough to remove any slack and then take 3-4 seconds from the time weight begins to register until it breaks.
My cheat record is a BESS score of 5.![]()
