Hello.
I recently acquired a small top loading kiln with an element in the lid. The kiln is 110v, with a heating cavity that is 9 inches deep (two bricks tall,) and 17.5 inches wide (simple dial control, but a thermocouple and analog temperature display were included in an accessory box.) I was thinking it could be used for heat treating with a few improvements, but wanted to see if anyone had some wisdom to share before I get too involved.
I was thinking about installing a PID, cutting a hole in the side of the unit (basically removing a brick, and using that as a door/plug for inserting and removing blades,) and either lining the bottom of the kiln with a layer of firebrick or filling the first 4-5 inches of the kiln with vermiculite.
However, I am not sure if having the elements on top (above the knives) is a great idea. All the commercial ovens have elements on the side, not on the top.
I was all set to order an evenheat oven, but balked because they wanted $350.00 to ship it to my location. I thought I would attempt to build one or modify a kiln instead.
Thanks.
Thanks.
