In my first test of the kiln I noticed that at about 1500 degrees the outside of the kiln became really hot (almost too hot to touch.) I was thinking that part of the original problem of it taking too long to get up to temperature may be due to the kiln losing too much heat (it is only comprised of a single wall of k23 firebrick.) I thought that by adding some additional insulation to the kiln, that it may reduce the amount of time it took to heat up. I was also thinking that the heating chamber was too large - at least too large for what I needed it t o do. I originally just wanted to add some K23 firebrick in the heating chamber to reduce its size. Unfortunately, no one in town had any (at least that I could locate.) I could however, find some vermiculite at a hardware store, so I thought I would try a little experiment to see what would happen.
In my second test I noticed that I could see in between the lid and the base after it was closed (just a little). I also did not put vermiculite all the way up to the height of the lid in the heating chamber as I am unsure what that would do to the heating element (I am thinking that there may need to be some space/air gap around the heating element - even if I do not want to use that part of the heating chamber.)
I am thinking that I could further improve the heating times of the kiln by adding more insulation to the heating chamber, and removing the very small gap between the lid and the base. All I really need in the heating chamber is a straight path - the rest of the octagon is wasted space for knives.
I am proposing to cut out one brick in the side wall (opposite the brick with the temperature probe hole) and use that for a door, as well as sealing the lid to the base with some stove cement (or some other way to remove the gap,) and adding as much vermiculite as possible in the heating chamber.
Unfortunately, no one sells rockwool/mineral wool in Juneau (they only sell fiberglass, foam, and cellulose insulation. Rockwool can be purchased via "special order."
I would have experimented with K23 firebrick, but my contact in Fairbanks is out of town until next week (and then I have to wait for it to arrive.)
The top of the kiln only gets slightly warm now (even at 2000 degrees,) so I probably could get away with using some plywood as a new lid base. However, I am going to experiment with some metal screen first.
