Yes I currently carry a knife at work. Both my direct supervisor and next manager up the line know about it. They have both seen me use it on multiple occasions and borrowed it to use themselves. Its an assisted open Kershaw with a 3.25" partially serrated blade. I do not think that Felony Stops additional 1/4 makes it look that much scarier. I also dress such that mounted on my belt you won't see it unless I am using it or retrieving/storing it. As far as I know a double edged blade is legal. And yes as GibbyX guessed I am looking for something to supplement or replace my existing folder. The goal is to find something that mounts on my belt on the opposite side of my body from my carry weapon. I am looking for a fixed blade that I can use to open boxes, which I do a lot of, and if necessary for self defense. There aren't to many times when given the choice that I would opt for a knife over my pistol but in those situation I think a good fixed blade would be ideal. Plus it puts it on my weak side so that if my strong arm is disabled I could more easily access it. Hopefully that helps explain a bit better. Thanks for all the input!
Mr. Ripley, I would highly suggest you research your local laws before putting it to the test and finding out the hard way. The "I thought it was legal" tends to carry no weight with the police or the judge. If you want to portray yourself as being responsible with a knife, then you should be responsible enough to know what is legal/illegal concerning knives, their carry and their use, period! And I'm not even getting into the pistol you mentioned.
Although I kind of jumped in with a snide comment on my first post, Long.Rider is correct in as much as we do not know the environment of his "office". It may be a gun shop, or a lumberyard or whatever. The OP has
not supplied us with that and only recently let us know his direct and one tier up supervision is okay with the Kershaw folder. But, he did express this notion:
"Also I need something that doesn't look scary. I work in an office and don't want people freaking out when I open a box."
Ripley, I totally understand your want for a small fixed, horizontal carry because I am still experimenting with something similar. That being said, alot of suggestions of alternates have been given (as you asked for) without any response from you on those models. So, it sounds like you are pretty set on owning the TOPS so, get it. Then, take it to work, preferably in the box it came in, and show it to your supervisors explaining your reasons for wanting to use it for work. Ask THEM if that would be okay. Then, you'll have your answer. Getting your answer AFTER an "office personell" gets scared and reports you and your only defense is "well, you were okay with the folder so I just thought..." wouldn't be pretty and could jeopardise your job. BUT, whatever you do I'd still say check your laws before you carry.
By the way, it's not the blade length of the TOPS knife that gives it a sheeple unfriendly look. It has that military, tactical, single-minded use look to it.
Gibby
