Mistwalker
- Dec 22, 2007
I just got another tool in for the urban studies project. It's a TOPS Pry-Knife. It's a little more suited to a combat or post-disaster rescue situation but for part of my studies I think it's a great tool. It has a blade shape and design that is well suited for working with materials found in an urban environment. It has a single bevel grind with a "chisel" tip. It comes in a ballistic nylon sheath that is molle equipped, has dual retention straps, and has has a large pouch on front for the accessories that come with it.
It has a heavy blade made of 1/4 1095 steel and it has two different types of heavily textured serrations much like the ones RAT uses (which I happen to like a lot).
It comes with some cool accessories. It has a pry, punch, and probe tool, a folding saw, and a z shaped slotted/philips screwdriver. The P.P.& P. tool is 5140 alloy with an RC of 55-56
while it's grind is steep it is still VERY sharp, and though it takes a slightly different technique to do so it will still whittle shavings fine enough for tinder.
The serrations make notching things such as v notches for hearth boards or trap triggers a good bit easier. The lower point of the chisel tip did fine for starting a spindle divot in a bearing block.
