Check out Fredrik Haaksonsen's website. He uses A8(mod) quite a bit. He also likes Vanadis 4 Extra. His knives are extremely tough, and they hold an edge well, too. He says that knife edges often lose their sharpness because of a lack of toughness and strength -- caused by micro chips and dents -- not just a lack of wear resistance.
http://xxxknives.blogspot.com
Also click on the articles on the right side that link to his thoughts on A8(mod) and V4E.
How sharp knives get initially depend mostly on the skill of the sharpener. Either of these steels can get extremely sharp.
You might want to work with a knife maker on the forum here to noodle out the best mix of steel, heat treat and geometry that works for you.
You asked for opinions and then get bent when someone offers one? You weren't exactly clear in your first post about just HOW tough the steel has to be for your unlisted needs. So, just what are you planning on doing with this knife that would make properly heat-treated O1 curl up in the fetal position and cry for mommy? Are you saying that a Randall in O1 is going to fail you? Have you ever actually USED a knife? You do know that a knife is for cutting stuff, right, and not for pounding into a tree or a brick wall to use as a step. Ya gonna pry open a locked car door after chopping through a couple of inches of ice just to get to it?
Not that it matters, but I prefer 5160, or L6.... Hope you find what you're looking for, but I kinda doubt it.
Depending on your price range ... my top recommendation would be a Carothers Performance Knife in his Delta 3V heat treat ...
Shannon Labs makes some great knives that check your boxes ...
Gollik another maker here uses Elmax fir some of his work ... it may not be quite the steel as the above mentioned but it's good ...
LT Wright would be where I would recommend you look if you want a knife today ... they have many models and offer some in 3V and some in AEB-L ... along with old standbys of A2 or 01 ... and they perform great IMHO ...
Fiddle back Forge has some knives that check most of your boxes also ...
And one last mention the Bradford Guardian 4.5" ... is a great knife ...
cpm 4v and m4 are way less tougher than the least of the ones i mentioned, cpm3v. not interested
So I think you're saying you want a steel that is:
- edge retention: good
- sharpness: very good
- toughness: the most extreme steel in existence that can also meet the above two qualities.
If that's the case, the best steels for you are probably (1) cpm-3v with the famous delta heat treat, as made by Carothers Performance Knives (CPK), and (2) INFI as made by Busse Combat with the famous Busse heat treat, and occasionally by the associated family companies Scrap Yard and Swamp Rat.
Those two will be followed by A8 (mod) with a good heat treat, and CPM-3V with a good (but not delta) heat treat.
Behind those will be a bunch of steel that have equal or better toughness, but start to compromise (a little bit) on the first two criteria (edge retention or ability to go to super thin and sharp geometries without constantly warping). L6, S7, 1V, etc.
So really I think the simplest answer to what you're asking is get a CPK or Busse.
But you’re not going to find a steel that is ultra tough with ultra high edge retention. So I recommended those because they have excellent balance in both edge retention and toughness.
thanks for the recommendation but i think cpm 3 will serve me better
3v is tougher than m4 or 4v. They are all excellent steels.
3v is still not going to be as tough as some of the carbon steels recommended by other members above though.
I'll make this super easy for you: get them both. That's what I did. Plus some Busse sr101 thrown in for a bit of fun.im even more undecided than i was before lol.
between delta cpk cpm3v, busse infi and the ones people said before
I see, however i dont want to lose sharp ability and edge retention a lot.
Whats your opinion with this against the others mentioned, like INFI and A8(mod)
I have no experience with Infi but A8 is even tougher than 3v but 3v has better edge holding properties. Even tougher than A8 is 5160 or S7.
How big a chopper knife are you thinking of. I think unless you are making essentially a sword then 3v is probably right at the sweet spot you want between a very tough steel with decent edge retention. 3v is also semi-stainless so that is also a plus.
You keep mentioning level of sharpness. It has nothing to do with toughness or wear resistance or ease of sharpening.
You can take two steels, from opposite ends of the spectrum as far as toughness goes, and get them both to hair whittling sharp. Exact the same grind, angle of bevels, thickness behind the edge, and a perfectly apexed edge at the same angles and grit for finishing. They would be equally sharp... how long they stay that way, and what kind of use would deform the edges would be different because of their composition, elements, amount and type of carbide, etc. Hardness is another number, but only part. Two different heat treat protocols can get you to the same hardness level, with vastly different performance characteristics.
I've owned and used 5160, 1080, 1095, 1060, etc etc (all the 10XX steels), 52100, SR101, INFIv(multiple versions and hardness of INFI), AEBL, 440c, 420HC, cpm154, Ats34, D2, A2, 8Cr13MoV, San Mai VG1, AUS8a, Carbon V, 12C27 Sandvik, and many other steels.im not thinking about right now.
I can get them all sharp enough to whittle curls on free hanging hair.
There is not one perfect steel. I like and recommend lots of steels.
You are asking for a tough steel with good edge retention. CPM3v is great. It is harder to sharpen than INFI, or 5160, or 52100, or 1095, or A2., etc. But it is not overly difficult to sharpen, or get a wicked edge on it.
Many of the higher wear resistance steels, af higher hardness will be more difficult to sharpen.
