"It has an ivory handle that has lost it butt cap. There are some wriggly lines on top of the blade. There is a little "sun" on one side."
Yes, it is - the handle is bone, and quite hollow, but filled with a well-carved piece of wood that matches its internal dimensions, into which the partial tang has been driven. The edges of the bone and the end of the wooden plug are covered with a layer of old laha which held the buttcap on, and was the weak link in the original design. Interestingly, this laha is reddish in color and looks somewhat like sealing wax, contrasted to the blackish stuff that HI uses, so it may have been a bad formula at fault.Berkley, is your example also missing the pommel cap?
Yup
Wouldn't surprise me to learn that the kamis add some locally available, er, organic materialOriginal fancy bowie fittings were not cast. They were thin sheet metal pressed (by hand) into molds, then filled either with lead or with 'rozil' = cutler's cement, made from rosin, beeswax, and brick dust.
Hi Golok - I just wondering that you might bought those Khukuris at the same place where I bought my 1st 2 Khukuris ... that is from a stall at ground floor of Pasar Seni, Kuala Lumpur! The problem with those Baraba @ Balance Khukuri which were sold at Pasar Seni is that their blade is too soft - I use those Khuks for cutting and diging - the edge is easily blunt, no chipping but sort of folded back. It is a tourist item.... The guy who sold the khukuri to me put the blade edgewise on his thumbnail (near the handle) and balance it. He said: "Look, perfect balance. A sign of great workmanship.' ...
Yes - as Berk mentioned in his posting - this Khukuris is epoxied to it's handle using a sort of sealing wax. Golok - in Malaysia they called this sealing wax as Gegala or Gala-gala.... the sealing wax which you called the laha on my khukuri is also reddish in colour ...
