Tracker's Forge Rasp and File Nessmuk
Feedback: +1 / =0 / -0
Hi,
I recently finished this knife, and here it is, for your consideration.
Instead of the usual rank and file, here you have the....
Rasp and File Nessmuk.
The Blade, measuring 5 1/2 inches long, is Hand Forge from a 3/16th inch File, leaving the file texture all along the sides, and it has an unsharpened false edge.
The Handle, being 4 1/2 inches long, starts with a Tapered Tang, upon which you will find a Rasp bolster, secured with Peened over Brass Pins, as well, you see a Hardwood Handle with multiple Brass Pins.
$180. If you would like a sheath, that will be an additional $55 dollars.
Thank you for taking a look.
Bob
