Sharp Minded
- Apr 6, 2020
***TRADED***
I'm the 2nd owner and have not used or carried it. The original owner, who is a well respected Member on BF said it was "not carried, only passed across a fine ceramic rod 5 or 6 times, gently. Passed across a strop with very little compound and cut some receipt paper."
From Monkey Edge:
Chunky one-off XL Tanto with belly profile and upper swedge with black oxide finish.
This hand ground one-off has a black oxide finish and a paracord wrapped handle. The molded kydex sheath comes equipped with velcro loop but will accept most mounting hardware/clips, allowing flexible options on how to mount the knife. Removing the lower screw from the loop lets you wear the knife inside the waistband.
Specifications
From Monkey Edge:
Specifications
- Overall Length: 9.125 in
- Blade Length: 5.25 in
- Cutting Edge Length: 4.625
- Blade Thickness: .215 in
- Weight: 8.1 ounces (without sheath)
- Blade Steel: Tool Steel
- Handle Material: Paracord wrap
- Included: Molded Kydex sheath w/velcro loop
