Originally posted by munk
There are a lot of variables here. I've said before that if the blade isn't too heavy a thinner edge might work better.....Weight does work for you.
I wish I could try a truly heavy blade but that will have to wait, until my wallet's a little heavier too.
Yvsa; isn't your full size Ganga Ram a heavy chopper?
munk
Yup, weight does work for you. And Munk if you want a heavy chopper sometime in the future I might be able to be talked out of my Super Salyan, notice I said, "might."
My Super Salyan is 3 1/2 pounds and is 20 1/4" oal with a 12 7/8" blade that's 11/16" thick at the bolster and 5/8" at the bend. The nicely convexed edge starts 3/4" away from the edge and is 9/32" or 1/32" over a 1/4" thick at that point. The blade tapers nicely from there up to the spine which is 2 3/16" further up. The blade is 2 7/8" wide!!!!
This thing is a virtual axe!!!!
The handle is 7 1/2" long from the bottom of the old style bolster to the top of the pretty old style Shop-1 scrolled butt cap.
The handle at the bolster is 5 3/8" in circumference and 7 1/4" at the bottom of the butt cap.
I had to take some material off so I could handle it safely so it is now about 4 1/4" in circ. in the center below the ring and around 3 3/4" center above the ring and the large swells at both sides makes it a very comfortable handle for me to hang onto now.
It is still in an unfinished state.
The rosewood handle cracked on me while I was removing the excess wood but I fixed it with super glue and the crack no longer exists nor has it cracked anymore since.
This khuk is definitely in the realms of the heavy choppers.
When you stand back about 25 feet from it it has the exact same profile as the H.I.Logo Salyan, up close it is stubby and doesn't look as well porportioned as it actually is.
I was gonna give you the specs on my GRS which is the "Friendship Model" that Bura made and when I went to dig it outta the safe I remembered it is still out on loan for a couple more months.
I think it's a tad smaller than the other GRS I had that I sold to Samuri Dave but not by much. They are in the realm of the heavy choppers too.
The Super Salyan is an excellent wood splitter while the GRS is a better felling khuk.
