I dig trappers. I've found for EDC a mini-trapper carries quite well and is very useful. If you don't have one then consider one of those too. I also like canoes, the look and their comfort in the pocket.
If you aren't sure and just want to try the pattern then I'd second the motion to try a Rough Rider or a Boker Magnum to see if you like it, then a Case or a Queen later. A warning though. I've always wanted to try the sunfish or elephant toe pattern, but not in a position to dump $95 and up just to see if I like it. I also like canoes as mentioned. About the same time about a month ago I picked up a Rough Rider elephant toenail for less than $5 shipped on a last minuted bid and I also picked up a Case canoe in smooth chestnut bone to go with the Case mini-trapper that had been my EDC for about the last year. Both were new knives. The Case was a 2013. Quite simply the Case was a disappointment and the Rough Rider quite a pleasant surprise.
The main blade on the Case canoe was rubbing against the tail of the pen blade and if you weren't careful on closing the knife that same blade would hang up on the back of the pen blade on closing. I had to pad the blade and put it in a vise then carefully tweak it several times to get enough clearance for the blade to close without hanging or rubbing. This was on a two spring canoe. Fit, finish, and walk and talk, between the 2013 Case and the RR were about the same. The Case was bought on auction also, but from a stocking, regular dealer so it wasn't someone's leftover.
Now my 2006 Case mini-trapper and the 2007 Case medium stockman (both in smooth chestnut bone) I picked up shortly after the Case canoe under discussion are both much better as was the 2007 Yellow/CV Case peanut. Seems that 6 years or so made a difference.
The moral of this story is that if you decide to go with a newly made Case canoe, check it out in person first or go with an online source that has a liberal return policy. I'm confident I would have had no problem returning the Case, but for the sub $30 price I paid for it I was okay with tweaking it more than the hassle of returning it. I hate having to return things. Not sure what Queen and others are doing now, but I would think they're probably okay.
Oh yeah, and the obligatory pics. I don't have the middle Boker anymore. I traded/sold my stag scaled Bokers as they were just too heavy in the pocket. I liked them, but they were in patterns I wanted to carry and that normally carry well, but the stags I kept noticing when carrying. The Boker and Boker Magnum's both carry well as does the 2007 forum Canittler.
The red bone on the right bleed out a LOT the first time I went to rinse it off after using it for lunch one day several years ago. I ended up rinsing it a lot then just dumping it in a cup of water I changed a few times, rubbing it down with paper towels between changes until it finally stabilized. Then I took it home and dumped it in a jar of mineral oil for a day. For all the dye that came out of it you would think it would have faded, but I just took a look at it to be sure and it's darker and much more even looking that in the (old) photo. It looks quite nice in fact. Not bad for $10 and cuts well too.
So what it comes down to is that, yes, you should get a canoe. There's just something about them that's down home. Not to mention that the scales are wide enough and the pattern shaped just the right shape and size that they make a nice worry stone for your pocket.
I may have to start wearing that photographer's vest just to be able to carry more knives.
