Sam - wow dude, how impressive! Yesterday & today I tried to sharpen my bm 940 (s30v) so I can shave with - hmm ouch <= no where as smooth shave as my endura vg10. I've waterstones, diamondstones, natural, ceramic, compound: diamond/cbn/cro from 10um to 0.1um, bare horsebutt & cow leathers . Any pointers for me?
LOL Well, you're already working with a tougher medium than I am. You have an awful lot of blade to grind on and much harder than my blades. These opinels have very thin blades that aren't super hard.
I suspect if you ask anyone else here, I'm doing things all wrong, but I can tell you exactly what I'm doing if you think it will help you.
I rough honed both blades on a DMT Coarse bench stone to set the angle and get a burr on each side. Then I moved to a DMT Fine bench stone and later a DMT Extra Fine bench stone. On those stones, I evened out the sides and chased the burr back and forth until it was gone. When I had it sharp enough to catch hairs and the blade had no detectable burr, I moved to a spyderco UltraFine bench stone for polishing. I finished up by stropping with a sheet of newspaper wrapped around a block of wood. I used Flitz metal polish to polish the edge. For the stones, I used the "take a slice off the stone" method... For stropping, I used a trailing edge method.
I seem to be spending far more time stropping than I expected. I have gone back to the UltraFine stone a couple of times using a trailing edge technique when I found aberrations along the edge, but only very lightly.
I am using a more acute angle for stropping than I did for honing.
You have a lot more equipment and a lot more experience with your gear than I have. I used natural stones exclusively for the first 10+ years. Then I switched to diamond. I've had the ultrafine ceramic stones for a couple of years. This is my first real experimentation with stropping and I really don't have anything suitable. I don't have jeweler's rouge, compound, or even a strop. However, I have to say that newspaper and Flitz is working very well, if a tad slowly. In this case, that might be a GOOD thing. I can definitely see incremental improvement as I go.
Good luck. If there is anything I can do to answer more specific questions, I would love to help out.
Sam
