- Dec 10, 2006
Really? Thats weird because mine has both on both sides
Jip. Can find some pictures for you if you really want me to?
Well i did try stabbing a pineapple juice can (steel i think) and the pointy tip got chipped in the 2nd try hahaIt's a great testament to the sturdiness of the triad lock that you can use it as a throwing knife or an axe to baton trees down and the lock will only develop minimal vertical blade play. Sounds like it's time to buy another and use this one to see how many holes you can put in scrap metal before it breaks!
No the pin at the blade has a wider diameter than the one on the bar that acts as a seesawAre the two pins the same diameter...the pin at the blade, and the pin at the lock bar?
On my Lawman, the pin at the blade has one groove in it, and the pin at the lock bar has two grooves in it, so it makes me think these pins are different for a reason.
The lock bar is bottomed. This means the abuse has peened the locking surfaces and all the corrective adjustment has been used up. The lock will not fail, but you won't be able to get rid of the play without replacing parts. Rotating and locktiteing the stop pin might help. It would depend what parts are damaged the most. You could just keep it as a beater and get a brand new AUS8 version for 25-30 bucks.
