- Feb 26, 2002
I decided to do some work on one of my khukuries. The end buttplate was loose (there was a fine gap between the wood and the buttplate) and the leather of the scabbard was looking a bit dry.
While waiting for a nurse friend to get me a fine needle to use to squirt some superglue under the buttplate, I decided I would oil the wood - one coat of oil on each of two days. On the third day I received the needle from my friend and low and behold when I checked the buttplate, it was perfectly tight. I was amazed at how easy the cure was for the loose buttplate and amazed at the amount of shrinkage there must have been in the wood that was fixed by coating it with some wood oil.
The next problem caused severe heartburn. I coated the leather of the scabbard with leather conditioner. I had previously used this leather conditioner on new shoes to soften them and it worked perfectly - on shoes. I followed all the directions including placing the scabbard out in the sun to open up the leather pores. At the end of the day, I tried to return the khukuri to the scabbard. It would not go. The scabbard had shrunk big time. The khukuri would only go in a matter of a few inches. I tried using sandpaper on the end of a probe into the scabbard. Unfortunately, some of the sandpaper eventually broke off inside the scabbard - heartburn was becoming chronic. After much work I managed to get all the sandpaper out and there hadn't been any noticeable improvement.
I then tried another approach. I use renaissance wax on all my blades. Wonderful stuff for stopping rust but not a terribly good lubricant. I coated the blade in a heavy coat of gun oil. Gun oil is generally a good lubricant. I then forced and I mean absolutely forced the blade into the scabbard. I then left it there for a couple of hours, pulled it out and reoiled the blade again. I did this over and over again but only oiled the blade three times. Each time the scabbard became a little looser. I don't know why this worked, but after 24 hours of doing this about 8 or 9 times, I now have a perfectly fitted scabbard. I still don't know why this method of loosening the scabbard was so successful - but it worked.
