Hmmm, I think Ill give it another shot at hard. Hard finish, would be like shellac, and if youve already experienced a linseed oil finish, then you know what soft is. Over-saturation with linseed oil can leave a gummy like feel to wood as well, and Ive noticed different woods react differently to linseed oil. Anyways, that is the beauty of oil finishes, is that they are durned easy to fix. If something is awry, just coat with more oil.
As for floor wax, I used to finish floors, and what theyd call wax, was actually poly-eurythane. As for not being able to completely remove wax? Not been my experience, anything can be removed, just a question of how much original material you will have to remove as well
Though with a surface finish, like wax, that sits on top of the wood, rather than penetrating into the wood grain, it tends to be easy to remove. Again, at least in my experience.
As for heat removing finishes, you can try and melt em, but in my experience the fumes have far out-weighed the benefits. Nothin beats good ol fashioned sanding for removal. Strippers can do funny things to the wood.
As for how to use linseed oil in finishing, I thought I covered it in my last post, but Ill repeat. Since Linseed oil is a penetrating oil, it is recommended to over-coat a piece, let sit (say 5 to 10 minutes) to allow the wood to soak up the oil, and then wipe of excess with a paper towel (dont use rags unless you can throw em out, its virtually impossible to wash out linseed oil). It takes a while for linseed oil to cure (even the boiled stuff), so let sit for at least 2 days, or longer depending on humidity. Then just steel wool or sand, and repeat until satisfied, or crazy.
Cutting the oil down with turp greatly improves penetration and drying time. Ive done a few pieces like this, and it really helps seal up cracks. But since Ive started mixin in Tung, Ive been much happier with the results.
Now IM lost again.
