Mistwalker
- Dec 22, 2007
Since Autumn is nearly here, and winter is just around the corner I thought I'd do a post on quick starting a fire under cold and damp conditions.
I really love writing threads like this because it gives me an excuse to go to someplace like.... this.
and play with my toys...um I mean tools.
The stuff in the green mylar packet is a compressed fuel called trioxane. It was given for use with the U.S. issue canteen cup stove.
It ignites more easily by another open flame but it will ignite by hot sparks also. The warmer the temp of the fuel bar the easier to ignite with a spark so in the coldest months it helps if you hold it under your arm or in another warm place for a while before you need to use it. It burns with a very pale blue flame that is impossible to see is bright sunlight. Though you cannot easily tell it the bar is burning in this picture. What will give it away, besides the heatwaves of course, is that parts of it immediately liquefy and puddle momentarily.
In a shady or dark place the flame is more easily seen.
Had I a lid for the cup, as I have noted some of you have for your crusader cups, this water would have reached a good hard boil. As it is it just barely boiled. It burns for roughly ten minutes.
It isn't all consumed and leaves a scar behind, thus I am not exactly fond of it for regular use.
However, there are those times when time itself is of the essence. At times such as those I am very fond of it. In the event of a cold, wet, hungry situation where having a fire very quickly is the priority...say in order to keep from succumbing to the elements or to quickly and efficiently provide food for a little one. And to do so without tying yourself up being completely devoted to tending the fire...this little green packet can be your friend.Using this as an accelerant to start damp wood you don't have to be so picky about the size of your kindling. You just ignite it and start piling on pencil size and smaller twigs.
