- Mar 14, 2000
OK guys, the results are in..
In regards to the HT processes that I outlined earlier in this thread. I just finished destroying, well, almost destroying my test blade and here are my results.
6" blade of 5160 - differentially hardened lower 1/3 of blade in Texaco Quenchtex Type A - tempered at 335 degrees.
-6 full length edge flexes over a brass rod. - No chipping!
-Average of 119 cuts (over three sharpenings) of 1/2" manila rope before it quit!
-1 90 degree flex with 2" of the tip in a vice. - No chipping or cracking.
-12 180 degree flexes with the same 2" of the tip in the vice. Still no chippng or cracking. Still in one piece.
- I wanted to see the grain of the steel so I put the first 3/4" of the tip in the vice and had at it. It looks fine to me without any of the fractures shown in the test steel earlier in the post.
- The blade returned to withing 25 degrees or so of straight after each flex.
- Just guessing but I would say the I had to apply about 30-35 lbs. of pressure to a 2 1/2' cheater pipe to go full flex.
THANKS ED, BILL and SHANE for the direction, coaching and support to my journey so far! You guys have given me a fantastic start by my standards, not to mention the ABS standards. Up next, JS test knife!
There has been a lot of nay sayers to what Ed has published as of late. To those people I say... Get out of the Lazyboy and try it for yourself before you start throwing negative comments around concerning something that you have zero experience. Maybe some of the steps could be altered or eliminated, but then, "why fix something that ain't broke"! It seems to be working incredibly well for me. To steel (pun intended) a phrase from a friend of mine... This blade is "WOW stuff"! At least to me anyways.
Fitzo - You may see Ed's comments as absurd, insulting and obnoxious, others view them as honest. Count me on the I appreciate honesty side of the fence. But then, I'm married to a New Yorker so I'm used to it
Later guys,
Rick
Later guys,
Rick
