Triple quench secrets to be revealed?(or not)
Even rlinger is talking to and with Mete, I engourage myself still to comment his words.
Why?
Because some newbies perhaps do not understand, that in the tests presented cryo did not help but rlinger says:
..... However I have experienced great enhancement by cryogenically tempering other steels both stainless and simple high carbon and certainly remain a firm believer in its incorporation.
5160 is very low carbon steel (0.56-.64 % C). All steels are not low carbon steels. Cryo helps to get rid of remain austenite. It is common sense that if we have lot of carbon we can get more easily remain austenite (not useful) and then getting rid of it better blades.
For example 52100 has 1.0 % C or even little bit more. BG-42 has 1.15 % C.
pig
back a long I had mentioned the cryo
I didn't think it was a big factor in a Rockwell
I still don't,( in total terms not just what can be seen with a tester)
but the time in an oven for SS
(over recommended time at hardening temp)
resultes the need to draw down at a higher
temp to get your target RC
still knowing
The great enhancement by cryogenics lay in the ability to use
a lower RC to aid in field sharpening the edge
and not losing the edge retention and ware characteristic of a higher RC.
deep freeze = Higher edge retention and ware characteristic
by being ably to use a lesser RC,,
gaining the benefit of both worlds.
in other words
with the cryo you won't add a lot of RC
but you add by deep freezing
a lot of benefits of the higher RC
and at the same time gain the benefit of a softer RC, by shooting for this target.
( less labor to bring back an edge in the field with SS)
for the lack of better words I'll call it the ,,,ghost Rockwell
the collective benefits that can only be seen in using the blade..
still not good explaining myself...:rolleyes:
Roger, many thanks for your efforts. My reason for being in these posts has been to get people to think logically and learn something about metallurgy, I think thats been working. 5160 should really be called a medium carbon steel and should be simple to heat treat as the test showed. Each steel is different in both properties and HT procedures.5160 is a fine choice for impact use , sword, kukri, or survival knife where hardness (Actually wear resistance) isn't the prime consideration .HRc 58 is fine for that. I and many other metallurgists choose 400F temper minimum because below that there are too many problems of cracking. If 58 Rc is not enough don't try to push it , pick another steel.For a good cutting edge I would choose something with about 1% carbon such as 1095, still a simple ,easy to handle steel but much better edge retention. Anyway thank you all for participating. Metallurgy rules !!
Thanks to all for the efforts so far. Great experiment. Controlling variables is so much more revealing than hunting around with methods.
I read thread quickly... think the summary is that the simple "soak 5 minutes" achieved same hardness as "triple quench, shorter soaks", wherein the soak times were ~ 1.5min to maybe 2.33 minutes each, three times. So in the neighborhood of 4.5 to maybe 6-7 minutes total soak time for triple quench. Quite interesting.
So far, the triple quench is a lot more work. (Can you hear the "however" coming up?)
However...
One of the things Ed Fowler (and Bill... please chime in here) seems to have been trying for with a triple quench is a reduction in the grain size from brief interludes in the austenizing zone. This implies that a 5 minute soak would cause relatively more grain growth. Smaller grain microstructure implies a couple of property enhancements, roughly in order of importance:
1. increased toughness at a given hardness (key benefit if it tests out)
2. easier sharpening... (modest value, would take it if I could get for "free", i.e. w/o other compromise, e.g. lower hardness)
3. finer ultimate polished edge potential (not a big issue really, not to me... not where I leave a toothy edge anyway, on a carbon steel knife which is likely to be a "big" knife, for me anyway)
Do you have any ways to check grain size in your samples to continue extending the learning in this (great!) experiment? Etch? "Free" metallurgical exam under a scope by some generous soul?
You guess right!
I am not able to resist the temptation to say:"You see, exactly as I forecasted!"
Read the following quotations and compare and think.
(1) pig, before tests:
I have a comment to the tests, in fact two.
Tests can scientificially thinking be best as you planned.
However, most practical smiths are relying on Ed Fowler's triple quench and test done by rope cutting.
If test is made in laboratory it is convincing to many but MOST of the smiths say: "Nonsense, they studied factor x and factor y in laboratory, in fact unknown factor z makes blades better with triple quenching, they did not make a real test which is a rope cut as Ed did."
To my understanding this is a key point.
If only lab tests done, metallurgists are convinced but they are already.
Smiths are not convinced as they are not this moment.
(2) Rob Angerer, after tests
However...
Your comment, mete?
pig
Pig, yes I'll throw in some comments. I will repeat than there is some paranoia about grain growth. The standard hardening temp for 5160 is 1550F. I used 1475F thinking that those using a magnet might end up with 1475 which of course will cause less grain growth than 1550 especially since 5 min is a very short soak time. Roger was supposed to fracture the samples to get a relative ( not a number ) grain size, again I don't think there will be any difference. As for Rob's comments - at Rc 58 it should be tough certainly better then pushing for higher hardness. I keep hearing comments on 'harder to sharpen' well I have for years done most of my sharpening with diamond , which will sharpen even a carbide drill bit so that's not a problem for me. Also I never polish an edge I just do a micro serrated edge. Let me get back to my Spaten Optimator.
First of all I want to thank Roger for his time, energy, and efforts! I think it's a great thing for people to come together like this to try to expand their knowledge. Thanks to Bill Burke for his time and materials also!
Rob, Thank you for bring up your point in regards to refining the grain structure. You got it out before I could. Ed is getting super fine grain structure (I believe it's in the 12 -14 range) which is off the charts (so to speak) from the reading that I have done. It would be a lot more interesting to me to find out if there is a grain size difference between the two test pieces.
From my own experience (using Ed's and Bill's forging/HT recipe), the 400 degree temper was quite a bit higher than I have needed. I tempered at 335 degrees. I have not had the opportunity to have my blade scientifically evaluated but it passed the brass rod test (edge flex), cut like there is no tomorrow (hemp rope) and will bend 90 degrees without breaking. The point that I'd like to make is that Ed and Bill have developed a complete package, from the temps that they work the steel to intermitent quenches while forging, to specific quench oil and temps of the quench oil, to putting the blades in the home freezer between quenches, etc. I don't feel that there is too much to be learned about the triple quench unless all of the pieces of the puzzle are going to be used. It might be that the triple quench only works in conjunction with forging at low temps or some other combination of events, maybe it's not even necessary at all.
It would make more sense to me to start with two knives, one forged and HT according to ED and Bill and the second stock removed and textbook HT, to see what the differences are and then work backwards one step at a time to identify where the performance gains are coming from.
Maybe some time can be saved by using a soak time at temp as opposed to the triple quench, but what are the differences in performance of the two final products? Like Rob said, is there a difference in grain size? Does the single quenched blade (with soak time) perform as well as a triple quenched blade, or is it the other way around, or is there no difference?
Sorry that this is so scattered, but I'm trying to write this while parenting a very needful 3 year old:grumpy:
Rick
going back just a bit..
easier sharpening is just one of a complaints ,,
sharpening with diamond ,,sure
is good for the guy that knows about them
but for the next guy down the line may not know or may not want to buy one?
he may just see a name on the blade and say hey that sucker
sharpens hard. but the name is there
now the name is remembered good or bad....
another on the list would be toughness so as not to brake,
but still hold that edge,, to name a few...things to balance.
micro serrated edge,<< I don't know,
to think that you have,,
little needle points ready to brake off and or dull
I'll go with a sharp smooth edge.
think of it this way.. in between those little
points you have missing steel
it's like the tires on your car
if you remove every other rib in it
that tire will be ineffective much sooner, more PSI and less contact area causing faster wear,
works great for a short time but....
( at the least your blade will be worn out much faster then the one with more steel to work with,)
I'm pretty sure you're going to be re-sharpening more often with a micro serrated edge
we're looking for the fit all blade
but it won't fit all
and do all well at the same time.
Carpet cutting,meat cutting, chopping wood,butchering or just for skinning,,
or any one of the many more tasks meant for knives,
the right blade for the right job it's meant for.
but still made in a fashion that is the best way known and possible by the maker.
the ones that don't work, will be weeded out by the user .
I know most of us know that but some don't , very good thread.
I have all three samples here intact and would like to send them to one of you that is both objective without bias and used to looking at and comparing grain structures.
Please advise.
RL
Please understand I'm not trying to be academic or dismissive about this testing. This is good stuff!
Grain structure is a very good indication of a quality heat treat. It is, however, somewhat indirect. What I'd REALLY like to know is harder to get to... and that is this question: "How much does grain refinement improve toughness".
You might answer that question by stating "5160 is very tough already, so why bother?". That misses the point that I happen to be intersted in understanding. (We might want to triple quench, say, O1, or 3V, or A2, etc. A2 is fairly tough, but not like 5160. Would triple quench help A2?)
What I'd really like to see is how refining grain structure yields measureable differences in, say, a Charpy V or C notch test, or some other well understood, repeatable test of impact toughness. But I know that Charpy machines are harder to find and than Rockwell testers among knife makers(!).
To me, one of the primary reasons to use a carbon steel blade is because you get an inherently tougher blade, JUST by choosing to do a good job heat treating 5160 versus, say 440C. I want tough, but I want really tough and very hard also.
So, to dismiss the issue of grain refinement's potential increase in toughness misses this idea... and I'm going to make up some data to illustrate (and assume Charpy tests can be easily acquired, big assumption):
Let's hypothesize that 5160 single quenched to Rc58 registers, 100 ft-lbs in a Charpy C-notch test.
Let's hypothesize that 5160 triple quenched to Rc58 tests out to 120 ft-lbs on the Charpy C-notch test. A ~ 20% gain is nothing to sniff at.
That is a benefit of going to the trouble of doing the triple quench. And a measureable one. I can measure grain size, but what does that translate into, repeatably and measurably?
As a knife buyer [this is basically my opinion now] I would PREFER to have a triple quenched 5160 at the higher hardness of Rc61 (instead of Rc58) if I knew triple quench would yield a blade of 100 ft-lbs at Rc61, same toughess as single quench at Rc58, because the harder edge will:
1. resist edge impaction, denting, and bending better
2. cut things like rope and game longer since edge won't roll as easily or, perhaps, abrade as rapidly
3. and it'll be harder to sharpen [but personally, I don't care because I use diamond stones, and they make small, not-so-expensive diamond stones that can be taken to the field also... we are talking about an expensive custom knife in the first place, so a $15-$20 stone is pretty small amount.]
I'm a knife customer, so a maker that can offer me 100 ft-lbs of 5160 tough at Rc61 is the maker I'll choose over the guy who offers 100 ft-lbs of 5160 tough at Rc58. Just personal opinion now.
OTHER customers might want an Rc58 blade triple quenched at 120 ft-lbs, because they like their knives to be easier to sharpen. That's ok too. It's still a triple quench benefit.
So, I would like to know about toughness improvements from triple quench first, refinement of grain structure second, and to me as a knife buyer with opinions, ease of sharpening is WAY down the list.
Ok, that was viewpoint #1, above... show me the Charpy, then the grain.
Viewpoint #2 is also valid, and ideally, we could analyze also (although it would be more difficult to reproduce cutting results, read on...). Here it is in short form.
If refining of grain structure through, say, triple quenching also yields some kind of benefit in abrasion resistance of simple carbon steels and low chrome carbon steels (52100), then another benefit is that the knife will cut, say, same amount of rope at a lower hardness versus a single quenched blade with larger grain. Lower hardness usually means tougher down to some point, and while softer usually means you give up some strength, and it also means easier to sharpen to some degree... e.g. if one only has more ordinary stones or a rock out in the boonies. This is a valid benefit to grain structure improvements, just not the one I'm interested in.
So in summary, I'd appreciate if rlinger could examine grain somehow... mete can you help with methodology? Can a 10x loupe help? Acid Etch and what to look for on the samples (Bill?).
Does anyone know who could test these samples for toughness? Or would you need a differently sized sample to set up the notch tests?
Sorry, was trying to make sure I was clear, it got longggggg. It's harder to be concise and clear.
All very good posts..
I like the way people are talking about the test findings, and what they might point to...
Im new to this sport, so I have a beginner question:
Is a 5160 blade with a Rc hardness of 58 way easyer to sharpen than the same blade somehow bumped up to 61?
A heat treating that results in easy knives to sharpen are what I seek to learn from you guys...so if you are saying that 58 RC is good for my needs, I will be happy to hear that...
DaQo, I believe alot of it has to do with retained austenite and grain structure. With all things equal a 61 should be harder in grinding than a 58.
RL
When I started this thread I assumed that American people are straight and not afraid to be wrong saying something.
I was mostly right.
Discussion is still coing on very well.
Many active paricipants doing useful tests.
To my mind this kind of thread is mostly a tool to have new ideas and facts, not to solve anything finally for ever. And I think, lot of useful information coming out.
Participants so far:
User Posts
rlinger 29
pig 27
mete 19
DaQo'tah Forge 17
burke531 8
Jason Arnold 8
Rick Baum 7
Graymaker 5
itrade 5
peter nap 3
Silent 3
Sethhoward 3
Burt Foster 3
Rob Simonich 2
NickWheeler 2
rdangerer 2
ddavelarsen 2
Gib Guignard 2
Royal 7 1
Don Powell 1
John Frankl 1
John Andrews 1
jhiggins 1
One thing I did find is the easyness to misunderstand.
For example I said 5160 is a low carbon steel, I meant that this is the blade forum and 5160 is on the low end of all possible blade steels.(Here again I mean only old traditional blade smith steels widely used)
Mete corrected it to be middle carbon steel (as it is from the point of view of the whole metallurgy including not hardenable steels and rare very fancy new alloys).
Also I asked mete to comment at general level the situation that I guessed, only HRC test done to be a problem for practical smiths more interested in "user level tests" as rope cutting.
Mete answered but speaks only details of grain size.
One thing is that I am afraid to be offended many bady. Why? Nobody commenting for a long time even I asked comments using the word "please".
Please, say straight if I am too irritating (so I can learn).
Also, I think that if some irritating person is presenting a good question, it is possible to forget about "the personality matter". Is it?
To the previous comments about 5160 HRC and blades. If The HRC of 5160 is 61 it is almost as a piece of glass, even it is a tough steel generally speaking.
No hard feelings: pig
Pig, the only problem is that sometimes I'm not sure if I understand your finnish/english or you understand my english/metallurgy but that works out in time. Hardness - if I remember Dozier knives of D2 are HRc61-62. That is an appropriate hardness to use with D2 but 5160 is more appropriate at 58. For edge retention (not hardness) the extra carbon of the D2 gives full strength matrix plus carbides.You don't get this with 5160.Hardness is not the best measure of edge retention.
pig, these threads have a way obtaining a mind of their own. They are a bit hard to control. A little gentle persuasion in getting them back on track is fine, but a few of your comments sounded a bit defensive and overbearing when people took the thread in slightly different directions. A question phrased to refocus the discussion is usually all that's needed. But I also realize English isn't your first language, and I admire anyone who can speak more than one language well enough to post on a largely English speaking forum... that's for sure.
Rc61 a piece of glass? Not even close if it's been tempered properly. Actually, I was just making up numbers to some degree to illustrate the point. However, plenty of makers run ATS-34 and D2 and BG-42 to a target of Rc60-61. Benchmade targets Rc60-62 for their M2 folder blades. I've never used a Maddog knife, but believe he targets Rc62 at edge, Rc50 spine in O1. It's not an unreasonable target, just depends on what you want.
I'd guess you can get Rc61 as tempered out of 5160 at 0.6% carbon? Anyone?
I think you could say that most steels above Rc 63 is getting pretty hard and would be relatively brittle. But depends on the steel.
mete,hmmm..........
Yes, true, for example now I am honestly wondering did I say clearly in my previous post "5160 + HRC 61 is as glass", I think I did. And I agree your argument about 58 HRC and 5160, ....but, you do not believe this or hmm.. what....hmmm...I do not exactly accept my Finnish/English or metallurgy for example in this case.....:confused:....
So, I think I said and I think I agree with you, but you think I do not agree or ....hm.............
Anyway, this general level question about test procedure and smiths attitude in general still unanswered! On purpose?
:grumpy:..........
:confused: :confused: :confused:
pig
Dozier targets Rc60-61, per his webpage, but I'm nitpicking. Sometimes AG Russell would quote Rc60-62 for Dozier's knives, but not sure why.
Hardness is not the best measure of edge retention, but it isn't the worst either. Edge retention means a lot of things:
1. resistance to edge rolling
2. resistance to impaction
3. resistance to microchipping
4. resistance to abrasion, abrasive wear
I'll be quite prompt at yielding to mete, a metallurgist, on technical points, but hardness is the one relatively easy to measure thing that affects #1 and #2 strongly, and #3 somewhat indirectly (transverse toughness may be better?) and inversely, and #4 indirectly (where hard carbide content tends to be a more direct method of thought about construction, and some adhesive or abrasive wear test is a direct method of measurement).
Example: perhaps bending strength would be a more direct measure affecting #1, but knifemakers don't speak that language generally.
Anyway, I understand the "hardness isn't everything" mantra, and it isn't, but it is a very good indicator of what you are getting in a knife, if tempering is done properly.
mete, maybe I'd understand your point better if you expounded on this thought a bit more:
To rdangerer:
Thanks about your answer. I read it with time very carefully.
About HRC detail:
5160 with HRC 61 is as glass. I stick with it firmly (at least this moment):
Because maximum hardness of 5160 is about 61-(62) directly from quenching this means that if it is still that after tempering you have not done any tempering. Steels with max HRC 67 for example are tempered properly when HRC is 61 on the other hand!
right?/wrong?
pig
Ok, eat my own cooking... gentle persuasion attempt follows ;) :
I'd rather the thread not get "stuck" on whether Rc61 is appropriate for 5160. Substitute "O1" for 5160 in my long post, or subtract 2 Rc points from my Rc number examples if that helps.
In any case, a reiteration (re-irritation?): the next step I'd like to see for this interesting experiment is that if triple quenching, a more laborious process, has grain size benefits, I'd like to understand that.
And more directly, if grain size is reduced, how can we measure the benefits in a way that is repeatable way (holding other variables somewhat constant, e.g. hardness), in a way that makes a difference to a knife user? An increase in toughness is, to me personally, the most interesting potential benefit of reduced grain size, although there are other potential benefits also (~ easier to sharpen maybe, etc).
