- Aug 12, 2002
OK, I have all kinds of questions today, so will try to keep them segregated into threads. and if you can just point me to good tutorials to answer them,t hat'll work too. I have tried to check all the tutorials I have bookmarked before I asked any of these questions though.
OK, I've been using a triple temper on my blades so far, and it seems to work alright. But I have also seen mentioned a triple quench and then triple temper. I don't quite get how this works. Do you do a quench, a temper, a quench, temper, etc? Or do you quench and let cool three times, then temper three times. The problem I see with the second method would be that you ahve the blade in the fragile/unstable quenched state throught hose three steps, so it seems likely that you might drop blade or something and lose allt aht work. Not sure. Anyways, any tips on this would be greatly appreciated. Also, since it is related, if anyone out there uses the Goddard Goop quench, what exactly do you use? I have some ATF, a big can of crisco(or rather, the generic kind from walmart) and about a gallon of leftover wax from old candles and stuff. I was going to melt this all together and put it in a cake pan, as he suggests in $50 knife shop, but I was wondering if anyone had suggestions on ratios of the fat to the wax to the atf or oil.
