Trizact CF belts
Hey guys, I ordered some new belts, and after hearing good things about the gator belts, I got several. I have heard a few things, like they dont play well with water, they leave a nice finish and also that they are slightly concave. My real question is about how well they cut. I have heard of many makers using them at higher grits, but I got a few lower grits and was wondering how well I could expect them to cut for bevel forming. Thanks guys.
I am a newbie but I would use ceramic belts for cutting the initial bevel. I think the trizact would work fine to refine the bevel though and for post heat treat clean up and finishing.
Trizact belts aren't low enough grit to grind bevels. Like Maelstrom mentioned they are a finishing belt.
You want 36 grit or at least 60 Grit for grinding your bevels. I start with 36. Then go to 60 and then 120 grit ceramic belts and then I would go to a structured abrasive belt for finishing.
I like the VSM belts from www.trugrit.com or the Merit Best Value belts. All ceramic and all available from www.trugrit.com
I use them after 120 ceramic. I usually go 60, 120, A100 Trizact, and I think A45 Trizact. With kitchen knives or full flat with no prominent bevel line, I go to a blue scotchbrite.
I like to grind with 36 ceramic, 60 ceramic, then go to a Gator A100, which is like 180 grit-ish. I find it gets 60 grit scratches out pretty handily in the steels I work with.
