- Dec 5, 2013
Ok guys, I am stumped on this. I am doing a tanto folder blade in Aldo's W2. I've used steel off this bar before and got good results so I know it is W2. The blade in question is about 3-1/2" overall length and about 1-1/4" tall. Thickness at the spine is .170" and the edge is hollow ground to .035" on a 10" wheel to about 2/3rds of the blade height. I thermal cycled at 1600, 1475, and 1425. Cleaned the blade up and applied a thin swath of clay (satanite) covering a section of the spine and a narrow strip on each side near the top. Brought the blade to 1450 and held for five minutes. Quenched straight into Parks 50 at room temp which was about 60 degrees. When I hand sanded the blade to clean it up, I couldn't see any hamon. I etched it for five minutes in FC and nothing; it just kinda turned gray and no black like you get if there is decarb. I ran a chainsaw file across the edge and it seemed to cut too easily. Checked hardness near the lockface and got 30c.
At this point, I thought about everything in the process and remembered thinking the blade seemed a little dark when it came out of the oven. It was however, certainly orange; well brighter than a black heat. I also thought maybe my clay was too much. I cleaned the blade up again and re-clayed it. This time I did a very thin Nike swoosh on each side and no clay on the spine. I set a two stage heating with a five minute hold at 1400 then ramp to 1460 for five minutes and again, quickly into the Parks 50. Results are the same.
I thought about pre-heating the oil but I've also read several times that Don Hanson has no trouble quenching into room temp oil. I've also had no trouble in the past but, this is the smallest blade I've attempted to put a hamon on. I am hoping to have this ready for Little Rock but any other blade would look wrong so, I've got to get this figured out. Any thoughts??
Bob
The photo below shows the same blade shape as the one I'm trying to do in W2.
2016-02-06_08-31-55 by Bob, on Flickr
Bob
