Troy Battle Sights
Feedback: +7 / =0 / -0
Front site $120.00
Rear site $140.00
Email at Matt@MattDtactical.com
571-277-1103
Web site open mid Oct. www.MattDtactical.com
Thanks Matt Donohue
Stafford VA
All tex below from Troy site
Front Folding Battle Sights MIL-STD 1913 Fore-end Mounted (Black)
First Choice of Special Operations
Elevation adjustable with a fired cartridge case
Globe shape for fast target acquisition
Low .460" Profile When Folded
The Troy Folding Battle Sights have set a World Standard for design and quality by which all other Back Up Iron Sights are judged. They are easily installed and position the apertures at the exact same height as the factory sights. With no levers or springs to fumble with, deployment of the sight under stress is easy. The robust stainless steel cross locking system ensures your sights will remain up and zeroed in the most extreme combat conditions. To fold simply press the release button located on the left side of the sight. All Troy Sights feature a zero-canting attachment system for use on all military and aftermarket receivers. No tools are required for adjustment. Blackened Stainless Steel and MIL-SPEC Type III Hard Coated T6 Aircraft Aluminum construction. Available in USSOCOM Flat Dark Earth and Black. Made in USA.
Rear Folding Battle Sights MIL-STD 1913 Receiver Mounted (Black)
Protected Robust Adjustment Wheel
Replaces M16A4/M4 Carry Handle
Dual Same Plane Aperture
