I am wondering how many people here have used Tru Grits Heat Treating and if there have been any issues with the results.
Hardened edges don't bend. They either warped in the HT or something else happened. File test them for hardness to be sure.
BTW, this is a four+ year old thread.
Good guys down there. Jeff is an especially talented maker.
Four year old thread.
Since my last post in 2016 Jeff at Trugrit has done probably a hundred blades and they come back at the hardness I request, with a dot from the tester.
During this pandemic sometimes things get slowed down dealing with one thing or another.
You should not be posting in this thread.The only issues I have heard of from my customers that switched to me is blades way under hardened.
I’ve used PAUL Bos HT at Buck for over 26 years and never an issue because Paul BosI switched heat treat from Texas knife supply this last year and have been using Bos Heat treat in Idaho. Mr. Bos is retired I believe but his right hand man does the heat treating now. I am very happy with the dozens of blades (mostly CPM 154, 440C, and 154cm) that I had treated. Every single blade has Rockwell testing "dots" on it so I know that they were tested. I have not used Tru Grits services but I buy a lot of belts from them and service has always been fast . Larry
