In a huge surprise my Truper came in today, about 2 weeks early. I'll try to get pictures in later. Using my calipers I measure the blade to be ~2.18mm thick above the handle and ~1.19mm at the tip. Technically they sent me the wrong model, I ordered the injected molded handle (the only one I saw) but they sent me the riveted handle scale model. This isn't really a problem but comparing the machete to my 24" Tramontina, the Brazilian blade is thinner at the grip (~1.91mm) but less tapered at the tip (~1.51mm), and the Truper's handle feels like a cheaper plastic than the Tamontina. The greater taper makes the Truper balance about the same as the Tramontina (about 9"-9.5" from the grip). The Truper is "hueco en Colombia" (made in Colombia) and the edge is dull and will need a grinder/file session to be usable. You all were right, by the feel of it there's no point in trying to give this a stabbing tip, blade is very flexible. So this machete will be my grass/weed trimmer if we ever get enough rain for anything to grow. Since this is one of the few discussions on Truper machetes I can find online I'll list its stats in a nicer format below:
As an aside, I found a $20 5 pack of machete that others had posted in the past. When that comes in I'll post my haul in the other thread (if I can find it again) and start a new thread if I can used one of them for my project.
- Blade Length: 26 7/8"
- OAL: 32 1/4"
- Blade Width (max): 2 15/16"
- Weight: 1lb 5.34oz
- Orange plastic handle with steel rivets.
- Lanyard hole
- Caguayano style polished machete T-1173-27P
