- Feb 5, 2009
Hello, all.
I've been lurking on this site for well over a year now and have gleaned a load of information. So, first of all, I would like to thank all seasoned bladesmiths out there for sharing their skills and wisdom.
Okay. This is my second attempt at a knife. My first cracked during the quench, but I immediately realized my mistakes...or, well, I had hoped.
This knife, however, snapped while I was attempting to straighten a warp.
The steel is 1095. The overall design is a kwaiken kind of deal at 1/8" by 1" by 9", half blade and half handle. The hardening went fine except for a slight warp just past the ricasso, blade-side. It bent maybe 1/8".
Also, if this helps, I used a makeshift forge, charcoal, and plain water. I tested the edge with a file and it skated like it should all along the edge. I did some rough grinding on it with a belt grinder but most of the shaping was done by filing, so I doubt I overheated the steel beforehand.
Tonight I did two tempering cycles at 450 degrees for an hour each, first laying the blade on one side and then the other. After the tempering I tested the flex by pressuring the blade slightly with my thumbs...like you would go to snap a twig, you know? The blade flexed a bit and returned back just fine.
So I prepped a small vise, inserted the blade right on the warp point, and using very little leverage I barely pressured the warp, bending the blade just short of straight when it snapped.
I realized this could have been a defect in the steel, thought that's not likely as my techniques are still pretty sloppy. The only thing I could think of with my limited knowledge on heat treatment is that when the blade warped microscopic stress fractures formed.
If you all can think of anything to help me out here it would be immensely appreciated. So, thanks in advance to all of you!
Take care!
Joe
Take care!
Joe
