The stainless will have to be sent out for HT.
The O-1 can be done in the shop, but using a pair of torches will be problematic at best. If you have been getting good results with 1080, you might give it a try with O-1, but it really needs a little closer tolerance an soaking time. Might be easier to send it out until you get a regulated forge or a HT oven.
When people say that O-1 is forgiving in HT, that is a slight misrepresentation. It can be improperly heat treated, and still get hard....but will be lacking in some way. Either the hardness will be lower, the toughness will be reduced, or the steel structure will be inconsistent. All of these are important on a quality blade, so the more correct statement would be:
" O-1 can be heat treated with less than optimum procedures and result in a hardened blade with less than optimum quality. This is not to say that the blade will be bad, just less than it could be."
Stacy
