I only have the Edge Pro Apex model but it's the same concept as the Pro.How do these compare to edge pro professional?
My biggest problem with it was holding the knife blade steady on the table.
I remedied that by purchasing the Edge Pro magnet that affixes underneath the table.
The other thing I don't like about the system is that you have to tape the side of the blade
to keep it from getting scratched. I use my stones wet and all the slurry from sharpening falls
on the table for the knife to slide around on and get scratched. I've found that clear packing tape
works well and lasts for a full session. The suction cups also aren't that good but the Pro version has a
large suction cup on the entire base to help keep the thing steady while sharpening. I don't know how well that works though.
With the Apex I bought the
Clamp Bar from Edge pro that lets you really clamp the thing down on the edge of a work table. Next, the spine
of the blade buts up against a straight piece of metal that doesn't always match the curves of the spine that well.
I purchased the 2 piece support from Edge Pro that is adjustable and holds the blade much steadier on the table.
Finally, there is no way to compensate for stones of different thickness. So I needed to purchase a little drill stop that slides on
the bottom of the vertical arm to allow for compensation.
My Verdict is that the Edge Pros can achieve fantastic results but the learning curve is steep and you need to spend more $ to make them
easier/more convenient to use. I think a clamped system is superior in many ways.
Well, the Hapstone RS comes in at under $300 which is a good price; but it has no stones.
This could be OK if it takes my Edge Pro Shaptons. Can somebody please verify that it does?
Next, does the RS include some sort of compensating system for using stones of different thickness?
Finally, what advantages does the RS actually have over the Work Sharp?
Thanks all
1. What ever you buy be happy with it.No, the Work Sharp Professional Precision Adjust can easily do knives as large as the OP has. It can also do small knives and very low angles because it comes with a magnetic table. And the stones are 1 by 6 inches, the same size as the stones commonly used on TSProf, Hapstone, Edge Pro, Kazak, etc.
I agree with what you are saying. My solution to the stone thickness problem is to use stones that are all the same thickness.I only have the Edge Pro Apex model but it's the same concept as the Pro.
I agree that it's very convenient to have all the stones with the same thickness.My solution to the stone thickness problem is to use stones that are all the same thickness.
But if not you can use angle cube.
One set of my diamond stones are 6mm thick (aluminium base) , the other set is close to 8mm thick (plastic base) and my strops are close to 9mm thick (plexi glass base).
When I go for example from 6mm stones to 9mm strops I use angle cube to readjust the angle. It takes a couple of seconds.
So, why stone thickness is a problem?
You can also make all the stones the same thickness with Hasberg precision gauge tapes. You can get all thicknesses you can imagine.
https://www.hasberg-schneider.de/en/services/presision-thickness-gauge-strip-standard-dimensions/
