onlooker96
BANNED
- Jan 3, 2010
Did anyone do a comparison of these two chop ability wise?
They are both very capable and the advantages of each has been pretty much covered. One thing not covered is how do you sharpen your blades ... and what type of gear do you have ? The long flat edge of the FBM if using stones is easier to sharpen. The Zilla benefits from some belt sander skills ... and then stropping to keep the edge up. I also use a Spyderco Sharpmaker on the Zilla with the fine rods just to tweak the edge at the back near the handle and at the tip. I keep those a little bit sharper/thinner than the belly used for chopping ... as I want to have the belly edge robust and long lasting. Delicate work is doable with a Zilla up by the handle for fuzz sticks and up by the point for game if you don't carry a smaller knife. The same is true though of the FBM.
I carry my Zilla's in or on a rucksack for Camp use if walking any distance. I would do the same with a FBM too. Much more comfortable. On my belt I like a smaller lighter knife. Your thoughts of a SAR 6 and one or the other Zilla/FBM make sense to me. Either will work well chopping, but the Zilla when properly profiled is IMO up there with a Gransfor Brux Small Forest Axe ... and quite infront of an FBM. I have tested these together ... my old posts should be able to be found.
Carrying a knife on a belt for an extended period of walking as the "only knife" ... after years of experimenting ... I would go for a Basic 9 or the newer Basic 8's ... weight is the key issue ... you want a long blade but a light knife ...
I was in the same boat as you at knob creek except my other was the killa zilla 2 and after much finger fu!@@#$ I ended up leaving with the killa zilla 2 and I absolutely love it. either way you really can't go wrong with that much infi![]()
I think a lot of people are here on the Busse forums because they would rather pay more and get quality. There is a reason why the HI are cheaper...
