Tuesday night practice
I caught some flak from my Lady about doing a stock removal piece, and I have been wanting a Sheffield style bowie for myself also, so I forged and ground this one out tonight after work. I milled and broach-fit the guard, and will final fit after heat treat. I am thinking stag scales with bronze pins. Hollow ground on a 14" wheel again.
The old Sheffield bowies had cool stuff stamped on them, so I stamped mine True Make
IT'S A BEAST
Very pretty, great forge to shape skills.
Tell me about your 14 inch wheel They cost a few $, is it worth it ?
what kind of broach are you using to make the guard slot?
I've thought of making some custom broaches but I'm not sure if it's feasible or not.
No, that's just a bench grinder with a scotch brite wheel.
Hey count, thank you. The 14" wheel I am using is pretty much standard on the Grinders at my job, Bader Space Savers, a 3" wide by 136" belt. I love them, great for hollow grinding, does not make a "fragile" hollow grind like a smaller wheel would, a hollow grind on a 14" is very close to a flat. I will buy one for my KMG when I can afford one.
Hehe, my "broach" method only really work with bronze and softer metals, I mill an undersize slot then use a special tool, flattened pipe with the interior of the tang dimensions and pound it on, the sharp corners of the tang push and cut a burr and size the slot. There is a burr raised on the front and back of the guard, sanded smooth afterwards. I bring it within 1/2" of the shoulders, then will file it the rest of the way.
Sam, you are rocking it! Keep up the great work and I always look forward to more pics.
Awesome style and execution!
Dang Sam you have crazy good forge to shape skill! Can't wait to see this one done!
Thanks Fellas! Ruined a SUPER nice piece of stag cutting it in half to turn into slabs, sadly :(. So I will now get a dog bone, and cut that into scales and jig and stain it.
You might have better luck using cattle bones.
They are bigger and easier to come by.
Ht'd this blade today, had to get creative with the Kiln hehe but it worked like a charm. I got some positive curvature WHICH ROCKS. I quenched from 1510F, at a 45 degree angle into room temperature oil edge first.
Thanks man. FINISHED! 5160, 16 3/4" overall, 11 1/2" blade 5 1/4" handle 2" at the widest.
Why are you calling it "Practice" Sam... Looks like Knifemaking to me! Beautiful Bowie
