Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Lots of questions with a variety of answers.
If running a tumbler for heavy surface removal and de-burring, a re-circ system is really needed. The amount of swarf and such can make the tank muddy, and bring the finishing to a halt, or change the surface look. If doing normal surface finishing, a charge of a little water and burnishing soap is all that is needed. Some finishes and media will be used dry.
If running a small batch of parts, you just take them out as they come to the top. Larger models often have a tip and dump system with a grate.
The smaller models can be dumper from the 5-6" door into a bucket with a strainer top. The media passes through and the objects sit on the grate.
These are vibratory units, so RPM isn't really an issue, but like most motors, the one in it is about 1750RPM. Depending on the type and power level, Some can be controlled, but they are three phase and more expensive. The unit I have the parts for has three phase motor with an off center cam weight. It transfers hundreds of pounds of force to the drum to move it back and forth to shake the tank. It has a controller to set the amount of force and speed.
