I think thats a virgin chicken and 1 burnt used sweat sock ashes. Rub the mix in with the other sock.peter nap said:As usual, I have to be the oddball. Johnson's/beeswax mix with a little turpentine, chicken feet and burnt sock ashes.![]()
TJ
Bees wax is carried by Hobby Lobby and Michaels Crafts in the candle making section. Sounds like Balistol will cure warts.ddavelarsen said:... Balistol/beeswax sound good too. Wish I could find either one locally. But not. ..
shgeo said:I like teak oil better than tung oil these days. Sand and oil repeated coats until it gets where you want it and then burn in hard (pure) Carnuba wax. It looks a lot better than any plastic varnish and you can still feel the wood.
The teak oil works well on antler, also
shgeo said:I got pure Carnuba wax from WoodWorkers Supply. It came powdered and I made small blocks by putting some in small tupperware and melting it by floating them in a pan of boiling water. Then you pop the block out of the plastic mold and it is very hard.
I use the block to get some wax on a linen buffing wheel and then burn it in with the wheel.
I let it sit for a while to get hard and then do it again. After several coats, it gets to looking like a plastic finish, but warmer. You can buff it back out for quite a while as you use the knife before having to rewax.
