Do you have some pictures ? It seems weird to me that they use that combination ? What is the purpose of pure tungsten behind tungsten carbide ?We use it in mining operations for our cutting machines. Once the tip of each bit wears out, we change them and throw the old ones away because the tip of each bit is tungsten carbide and the rest of the bit is tungsten. As a rough guess, we change 50 lbs worth of tungsten every 24 hours.
Tungsten carbide is close to diamond in hardness as aluminium is close to tungsten carbideI've got a bit of tungsten carbide drill bit I use for a paperweight, a legacy of one of my various careers (long story...). Terrifically hard stuff but I wonder how you'd sharpen it if you could make a blade out of it, as it's pretty close to diamond.
it's pretty close to diamond when compare it to things like wax or butter but yeah without context the statement can be meaninglessTungsten carbide is close to diamond in hardness as aluminium is close to tungsten carbideDiamond work better on tungsten carbide then on hardened steel for me. I mean they are not faster but they make more clean cut on TC .
What i was trying to say is that between 9 and 10 on mohs scale is huge gap/difference in hardness. 60 HRC steel will make visible scratch on 55HRC steel and you need to put some pressure to do that , but Diamond would scratch/cut Tungsten carbide deep and easy .No need to put any pressure just draw a line like we do with a pencil on paper.it's pretty close to diamond when compare it to things like wax or butter but yeah without context the statement can be meaningless
I know all that ,that s why it is used to make fake gold bar .I m not sure about what we are talking here ? Pure tungsten is not used for cutting aplications , we use cemented TC carbide .Its almost certainly tungsten carbide or just tungsten (ie. high speed) steel. Tungsten itself is very very dense, the reason its used in armour piercing projectiles so you can check it via its weight which is the same as gold.
