00ChevyScott
Basic Member
- Dec 3, 2010
I might try that nightman, thanks
Very good idea! I'll do that at work today! Should I do both sides?
Wassup? I thought the stop pin was round and the shrink tubing would slide over the pin and be heated to tight? Round pin = all sides right?![]()
Both of mine have vertical "play" if I grab the blade and really tug up and down. Matter of fact, all 8 0551s that I've held have had that.
I don't think you're experiencing play, especially since the oring trick did not work for you. I think you are experiencing VERY slight lock rock, which is just unfortunately a result of the design of frame locks. It is inevitable that MOST frame locks will have some "give", especially if you are looking for it.
Hold the handle, the handle alone. (with the blade in the open position) Now shake the knife up and down. Do you hear clicking from the blade moving back and forth? If not, then you don't have "play", you have some slight movement in the locking system, which is just going to happen. VERY few frame locks can avoid this. Strider and CRK are the only ones that I know of, and the way Strider fixes it is by having the lock meet at such an extreme angle that it wears out in 6 months. Stop obsessing over a TINY amount of movement and use the knife, it's not going to affect anything.
FYI the shrink wrap trick worked beautifully. It's not the prettiest thing in the world but it definitely cured the lockup problem. Thanks a ton for the suggestions guys.
Just googled and it does come in colors but black probably ties in to the handle slabs best.
Can you post a pic of the NEW lock-up too? Would be neat to see how much it changed? Also, did the packaging say what thickness heat shrink tubing it was?
